Full Send Society
Help diagnose a sound (video link)
I had my car (1977S with 54k miles) at the mechanic this winter for a lot of small maintenance stuff. When I got it back in winter it went into the garage while I did other projects- I didn’t drive it but 100 miles when I started hearing this ticking, pfft noise. I towed the car back to the shop where they determined it needed a valve adjustment, never mind they had done a valve adjustment when they first had the car.
They checked for broken head studs and didn’t find any, they retorqued the exhaust bolts and re-replaced the valve cover gaskets after re-adjusting the valves. The final determination was that it’s a 43 year old car.
Is this a noise that I should be concerned about?
https://youtube.com/shorts/9dI4NKFdvzs?feature=share
https://youtube.com/shorts/zIGWpeFa9E0?feature=share
-Julian
1977 911 S: Backdate, EFI/ITB, AC project in the works:
http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html
Old 07-20-2021, 04:58 PM
proporsche's Avatar
well? sound like they do not know how to adjust the valves...The only other thing is..does do it on cold engine and stays the same when warm?
Possibly broken valve spring and they did not check for that
try different mechanic
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 07-21-2021, 12:16 AM
It's something that changes rhythm with the RPM. That's a good enough data point that I would start with checking the valve clearances as Ivan says.
Old 07-21-2021, 06:10 AM
Listen to the chain boxes, it’s not likely that any mechanic would have missed it but it could be a chain ramp crying for help.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 07-22-2021, 07:04 PM
