Wer bremst verliert
JohnJL's Avatar
Carrera Flywheel Sensors - Which is top and bottom?
I lost track when replacing the sensors which goes in which sensor plug in the engine compartment. In a 1985 Carrera, does it matter which plug goes the the upper and which gpes to the lower sensor on the flywheel? I imagine they are picking up different timing marks, or have an offset programmed so want to get them plugged in right the first time..
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 07-29-2021, 09:57 PM
Stock, the top one on the flywheel bracket goes to the lower one on the engine bracket.
206 637 4071
Old 07-29-2021, 10:13 PM
Because Porsche…
Old 07-30-2021, 02:49 AM
Sensor orientation.......
This is the trick I use to remember the orientation of these sensors by using the alphabet (RST).
@ transmission side bracket:
R (reference) upper
S (speed) lower
@ cylinder head #3:
T (temperature)
Now, for the different connectors by the fuel rail:
Flip over the R/S/T orientation to T/S/R. The speed sensor (DG) remains unchanged and always at the middle.
Just remember your ABC...to.....RST.
Tony
Old 07-30-2021, 12:40 PM
Wer bremst verliert
JohnJL's Avatar
Thanks guys!
Old 08-02-2021, 05:45 PM
