Slippery Slope Expert
Lug Nut Education
How interchangeable are lug nuts wheel-to-wheel? By that I mean are the conical faces compatible/safe wheel-to-wheel, car to car? (Assuming threads and other variables are the same.)
Reason for the question is that I’m looking for some spares compatible with my SC and Simmons wheels. Would other nuts, like stock Porsche lug nuts, work safely?
“As new technologies become indistinguishable from magic, and I can no longer tinker, the magic goes away for me.” |
Lug Nut Education Please
Question on lug nuts. Is the conical face on all lug nuts the same? By that I mean can you use any lug nut with any wheels (assuming diameter and threads are the same of course).
The reason for this question is that I am looking for some spares for the Simmons wheels on my SC and all I seem to be coming up with on searches are generic Porsche-compatible nuts. I tried to post this yesterday and it never showed up. Also I noticed no other changes in the board either. Forum malfunction perhaps?
ball cone Porsche oe wheels use an R13 ball as do VW, & Audi you need to be careful as there are sizes of ball seats R14 being a common one here is an R14 next to an R13
Mercedes used 12mm ball sockets.
No mixing seat sizes or wheels fall off no matter the tourque. |
RETIRED
Alloy nuts can crack at the base and a real PITA to fix. If you AX, DE, swap wheels a lot or race, consider open headed s/s nuts.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
They sell lug nuts without specifying what type of RIM you need to use...... that should tell you lug nuts are compatible with any rim.
If there is a nagging doubt ask your local tyre person |
Racer
Lug nuts are not compatible with any wheel. Porsche used radius (ball) lug nuts while most companies use conical lug nuts. Radius and conical lug nuts are not interchangeable.
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
