Heat not turning off
My heater is running even when turned off. What’s the deal?
Richard
87 Targa
20 LS 500
Old 08-25-2021, 07:56 AM
Flapper boxes stuck closed?
_______________________________
1982 911 SC 240,000mi and counting
Old 08-25-2021, 08:00 AM
creaturecat's Avatar
does the '87 have the 1000 dollar problematic NLA solenoids, as opposed to the earlier readily available 10 dollar chunk of wire?
Old 08-25-2021, 08:53 AM
Are the fans running or is it just pumping out heat all the time due to the heater boxes not closing?
Old 08-25-2021, 08:56 AM
7783911's Avatar
texas..do you really need heat, why not blank off the heater system?
Old 08-25-2021, 09:03 AM
Did you not see that Texas had below zero temperatures for over a week last February? It does get cold in Texas!
Fix the problem properly so you can have defrosters and be comfortable in cold weather. Block it off is as wrong and removing the AC system because it does not work. FIX the problem, and have a car that functions properly.
This is in Eureka Springs, Arkansas on a Porsche Palooza weekend to see the fall foliage. Great roads and great friends. It was 16 degrees that morning. I was really happy to have the kick butt heaters of my 911.
Old 08-25-2021, 09:14 AM
In can get chilly, but I think that may be the way to go.
Richard
87 Targa
20 LS 500
Old 08-25-2021, 09:15 AM
7783911's Avatar
Jeeze GH, I dont normally follow every states weather patterns, didnt mean to offend you
Old 08-25-2021, 09:16 AM
Heater boxes not closing.
Richard
87 Targa
20 LS 500
Old 08-25-2021, 10:46 AM
It has the red tipped levers between the seats so I assume the chunk of wire.
Richard
87 Targa
20 LS 500
Old 08-25-2021, 10:47 AM
Thanks everyone. I’ll take it over to Laszlo and hopefully get a broken wire fixed.
Richard
87 Targa
20 LS 500
Old 08-25-2021, 10:51 AM
Brew Master
cabmandone's Avatar
Probably just a spray and readjust. I had my stuck open less than 1/4 inch and you'd be AMAZED how much heat that let through.
Nick
Old 08-25-2021, 01:26 PM
7783911's Avatar
I had to redo mine (Canadian weather). Pulling off the old flappers can be a real pain, easier if you have a lift available. If you go that route, you can recondition but looking back, new ones are easier and almost as cheap given sourcing replacement parts. The key is the closure and if those flapper seals are in good shape (test with a blower to see if they let air through). The replacement of the wires requires pulling psgr seat out, then handbrake assembly to get to wires and then you can route them (again, a lift is so much better then squeezing under the car).
There are various guides to be examined to ensure they are in good shape and not binding
IMHO
bob
Old 08-27-2021, 06:29 AM
relube/readjust if necessary.
the "set screw" is tiny - best ensure it's soaked with penetrating fluid beforehand.
Old 08-27-2021, 08:31 AM
MichaelSJackson's Avatar
+1 on cabmando's point. Almost closed lets a lot of heat through.
Also, bob's point on replacing the flapper boxes is worth considering. I cleaned mine up, but they were pretty far gone and will have to be replaced next time.
Old 08-27-2021, 10:07 AM
