Broken 911 sc shift lever
Recently on a road trip my 1980 911 sc became harder to shift into 5th until finally the shift lever actually swiveled to the right while tying to shift to 5th. I was not able to shift to 5th after this and reverse was very tricky to find. The lever could be rotated at will.
Upon my return and inspection and teardown the upper part of the shift lever was able to be pulled right out of the gear shift housing with the lower part still attached with the shifter pivot pin in the shifter mechanism. The two teeth on the Lock pawl plate were bent but everything else looks good. Should I replace everything in the Shifter housing or just shift lever and lock pawl plate. I searched for similar problems but found none on the web. Thanks for your suggestions.
Old 09-30-2021, 06:41 PM
It sounds like a short shift was added in the past and the epoxy broke.
Bruce
Old 09-30-2021, 06:53 PM
MichaelSJackson's Avatar
+1^ Bruce has got it! Those early short shift kits were kludgy.
Go to the "911 Used Parts Classifieds" forum and buy a used 915 shifter (complete). Or sometimes there are used after market upgrades available?
If you remove the housing and can determine if the housing is sound, you could get a factory short shift kit that includes a shift lever and all the internals. (No epoxied extensions or spacers.)
Or jump directly to an after market shifter. (Do not pass Go. Do not collect $200.)
Old 09-30-2021, 07:11 PM
Thanks for the info. My broken shift lever looks like it was epoxied. Do you think re epoxy and a roll pin would fix things up. Everything else looks in good shape.
Old 09-30-2021, 08:25 PM
Just epoxy
Don
_________
72 911T Sepia 2.4
08 Audi A6 quattro 3.2
03 Toyota Tundra
Old 09-30-2021, 08:54 PM
Clean and weld is what I do.
206 637 4071
Old 09-30-2021, 10:24 PM
Walt Fricke's Avatar
A rural co-op welded mine back up when that happened at a rural race track. Worked fine, but they had burned a hole through the wall of the tubing of the lever, and a year or so later the tube broke. Have someone pretty good to the welding, or maybe braze it. I think solder would do. John doubtless can weld very well, as you would expect a professional to do.
If you like the shorter shift, purchase the factory short shift kit.
Old 09-30-2021, 11:09 PM
Cairo94507's Avatar
I vote for clean and weld too. Solve that issue forever.
'71 914-6 #0372
'17 Macan GTS
Old 10-01-2021, 07:21 AM
