what bracket is this?
I shut the passenger door on my '88 Carrera and this part dropped to the floor. I don't know what it is...any ideas? I think MAYBE it's an old bracket from the ac hoses that I replaced that run along the right/passenger side of the car but I'm not sure. It's only partial
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
Brew Master
Look inside the door latch that mounts to the chassis. You'll find a chunk missing either on the top or bottom piece. PP sells replacements.
Look familiar? https://www.pelicanparts.com/More_Info/RENDH27.htm?pn=REN-DH27&gclid=CjwKCAjwn8SLBhAyEiwAHNTJbQrLebVSNslA1heexqOk dk0qes1NrH4bqlvBVgrLJDJ7p3jIbbxR0BoCBRsQAvD_BwE
Nick |
it's a piece of the door stricker on the door jamb
it's broke |
that was a quick tie
Brew Master
Yep! But now I'm gonna show him how to replace them for the tie breaker.
![]() http://forums.pelicanparts.com/porsche-911-technical-forum/806739-plastic-pieces-door-striker-plate-replaceable.html I did this 7 years ago and sadly have to do it again. But 7 years ago I used some pieces I had laying around. This time they'll be new!
Nick |
This place is awesome! Thanks, I had no idea what it was.
now i'm shamed into fixing mine
Ok ordered 2 new from Pelican since I assume driver side door will need it as well. However, I thought I might have messed up since I removed the metal bracket (not sure of name) that this new nylon part goes into. After I got it out I realized it bolts into a loose plate inside the door jam. I had not marked it's exact position which I thought may have been a problem. I was able to find a clean/dirty line so put it back as close as I could and door seems to be working fine, although it does seem to be VERY slightly proud of the body skin so maybe needs to be adjusted a tiny bit. Other problem is how do I get the new part installed? It looks like the metal part is riveted together...am I missing something? I can't find a post describing how to install the new parts.
Brew Master
Take a look at post #5.
Click the link.
Nick |
Thanks Nick...I should have seen that.
Insert Tag Line HERE.....
Its a ruler from Office Depot..
Special order here: https://www.officedepot.com/a/products/692165/Office-Depot-Brand-Wood-Metal-Edge/;jsessionid=0000Kv6-xh4PuePKBZavLNFMimG:17h4h7dlm
Marc |
