I didn't know about Snapgap. I like it, might use in the future. I learned the old fashion way with feeler gage and combination of screwdrivers and 13mm wrenches I had. Soon I discovered the feeler gage holders and shortened feeler gages to make it easier to get them in and out. I think this is the right-of-passage method as mentioned above.
Sold: 1989 3.2 coupe, 112k miles
Old 10-27-2021, 06:37 AM
Pedro '84 Coupe's Avatar
Another fan of SnapGap. I think I could've done it the old-school way with feeler gauges etc but SnapGap made it quick and easy. I had enough room on the drivers side so didn't need to loosen or remove the exhaust.
2000 Boxster S and 2016 Audi A6
Old 10-27-2021, 07:29 AM
I use the long, 8”-10”,feeler guage.
Clean the surfaces well dont scratch the aluminum on either side, i use Dow 111 or similar grease on both sides of the gasket and dont overtorque the nuts.
Old 10-27-2021, 08:33 AM
Were you able to work around the A/C compressor without removing it as well?
Old 10-27-2021, 03:38 PM
No, I removed the 3 bolts that secure the compressor and set it aside.
Old 10-27-2021, 04:17 PM
Eng-o-neer
Tremelune's Avatar
Does anyone have a bad review of SnapGap? I had a terrible time with various feeler gauges. The Kirkland tool was nifty, but still pretty fiddly. SnapGap was very simple, and all my rockers have the same "click" feeling.
"Right of passage" is masochism, and 40-year-old cars have enough character to go around...
Old 10-27-2021, 04:35 PM
Reiver
Reiver's Avatar
This....I've done the old fashioned way, even used a Kirk tool once, and have had it done professionally by a great Indy shop.
With the snap gap (done 2 weeks ago) it has never idled this smoothly or sounded so uniform when running. I doubt, in my experience as noted above, that the lash have all been so closely set in tolerance and that makes a difference.
De Oppresso Liber
Strength and Honor 5th Legion
Old 10-27-2021, 04:49 PM
Formerly known as Syzygy
Canada Kev's Avatar
It's easy to just remove the bolts holding it on - some are saying three, but mine has four bolts holding it on, actually three bolts and one nut, all 13mm - Then pull its wire connector from near the oil tank and then flip it over and set it on top of the intake manifold. Done in less than five minutes. Do NOT disconnect any of the hoses. It also makes it easier to remove the air box cover with the AC hoses kinda out of the way, too.
Kevin
Old 10-27-2021, 09:54 PM
You must be taking the lower sliding mount off with 3 bolts and one nut, along with the compressor, instead of just the 3 long bolts holding the compressor to the sliding mount. Harder that way.
206 637 4071
Old 10-28-2021, 06:57 AM
Canada Kev's Avatar
I might be.
I for sure will take a closer look when I head out to the garage, tomorrow. I've got a trick worked out to get that nut back on with no swearing required and it still only takes a couple minutes to put the compressor back on and snugged up, but easier is usually better.
Thanks, John.
Kevin
Old 10-28-2021, 08:13 PM
rokemester's Avatar
I adjusted my valves while the engine was out for a suspension refresh. My first time with a 911. Previous valve adjustment experience a VW Beetle, easy peasy. Even with engine out of the car easy access I found this job to be very fussy. I vowed that if I ever have to do an in car adjustment I’ll use SnapGap (which I’ve purchased and have on the shelf), and I’ll need to move AC compressor and catalytic converter.
Northeast Ohio
1987 Porsche 911 Targa
1966 VW Beetle, 6V
Old 10-29-2021, 07:24 AM
I have used feeler gauges and the Stomski tool. The Stomski tool is far, far easier, and 100% repeatable and consistent. I will never go back to the feeler gauge for this.
Old 10-29-2021, 08:09 AM
Thanks to all for the replies. I too get a kick out of the feeling that one must suffer through doing the valves the hard way before using what sounds like a great solution that gives very precise results. I’ve adjusted many valves in my day and always struggled with the feeling that it’s just to vague of a process and not as accurate as it should be.
Old 10-30-2021, 07:18 PM
Bill Douglas's Avatar
Jeff, it's a good game plan to give it an Italian tune first. Burn the carbon off the valve seats and valves. If you adjust it with carbon on the valve seating area the valve will never close and you'll burn out a valve.
I take the covers off, rotate the engine as per the instructions and feel each valve's subtle click. In 25 years of doing my own SC's valves I've only had to adjust half a dozen. They really don't wear out or get out of adjustment much. If the valve doesn't have the subtle click, adjust it then. But there is no point in unscrewing the lot of them and resetting them.
If someone's engine needs a whole lot adjusted I think there is something badly wrong with the engine and that needs to be addressed first.
Old 10-30-2021, 07:38 PM
Racer
winders's Avatar
It doesn't really need to be that accurate. The spec is 0.004", (+/-) 0.002".
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 10-30-2021, 08:17 PM
Yep, the idea of the gap is so the valve really does close. So better more gap than less gap if there is going to be a degree of error.
Old 10-30-2021, 09:26 PM
Racer
winders's Avatar
It's +/- .002" because anything from .002" to .006" is just fine. The idea being that if you use a .004" feeler gauge and adjust the lash so it just slides in the gap between the rocker foot and valve stem, you are good to go!
Scott Winders
PCA GT3 #3
Old 10-30-2021, 09:33 PM
proporsche's Avatar
toby..by now you know how to go about it..but..one thing is very important..do not remove you spark plugs before adjusting the valves..it will be a little harder to turn the engine ..but not that much..the reason is..if you remove them some little carbon could fall into the valve seat and valve would not close all the way so leave them in ..
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 10-30-2021, 11:39 PM
Ivan
Great advice, thanks.
Old 11-01-2021, 04:19 AM
