Valve Adjustment '88 911
So new to me '88 Carrera Cabriolet. I have been researching the valve adjustment process and am thinking it will be one of my winter projects with the car. The car has less than 35,000 miles and very complete service records but from what I can see, the valves may have never been adjusted or it was not recorded. I feel pretty good about my ability to do it, I own air cooled BMW motorcycles so I am fairly familiar but I can see this is a much higher level of complexity.
My question is, does the A/C compressor have to be removed or can this be done with it in place. I read one overview that said to unbolt it and tie it in place, out of the way. Can someone better describe this? Any other recommendations that I should study up on? Thanks Jeff |
get yourself a nice clean double blanket.Remove the 3 bolts on the a/c compressor and move it aside on the right fender..this way there is no damage done.
On the left side remove the pipe to the heat exchangers..2 bolts on the heater motor and one hose clamp.this will give plenty access to do the valve adjustment on top.. there are also many way to do the valve adjustment..mine is like this..mind you i do it for almost 40 years...but if you practice with the feeler gauge you get there.... Ivan https://www.youtube.com/watch?v=O_ypBn_u7g8
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Do the Valve Adjustment AFTER you drain the oil.
Just don't think I'd be comfortable moving the compressor on top of the fender. Can you set it on blankets on top of the motor, behind the fan? Will the hoses reach?
Lift the compressor up and swing it over on top of the engine.
What John said. Put your location in your signature and maybe someone will stop by and check on your work
You might take a look at the Snap Gap valve adjustment kit...
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 10-26-2021 at 02:33 AM.. |
this cover..looks like it is still available..
I am just outside Grand Rapids Mi. I am seriously considering Snapgap. I think it looks like a foolproof way of setting the valve gap with such poor access. On the bench I won’t hesitate to use the feeler gage but in the car….? I may look at a cover like that, original paint is only original once.
The rear service cover is a must have.
I have one. Buy one here... https://www.pelicanparts.com/More_Info/BE002BC.htm?pn=BE002BC
Sold: 1989 3.2 coupe, 112k miles |
Heidi & Franny have a decent overview of the process on their YouTube channel, it’s worth watching.
https://youtu.be/6ciw3mDjz0k What model BMWs do you have? The 70s airheads are my favorites. |
Reiver
I've done them both ways and prefer the snap gap...no messing about.
De Oppresso Liber Strength and Honor 5th Legion |
It took me 4 in car adjustments to get the time down to something reasonable. This is how I do it with feeler gauge now:
1. I sketch the position of the valve adjustment screw for the cylinder I'm on firstly. 2. Then I'll try and fit the feeler gauge, if it doesn't go in fairly quickly I stop (this is the time waster otherwise). 3. I'll loosen the nut and unscrew by a turn and pull up pretty hard on the rocker, sometimes it seems like it sticks. 4. Then slip in the feeler gauge. 5. Tighten the adjuster by hand till it toucher the feeler, the adjuster is roughly back where it was before you started. We know that one turn of the adjuster is 1mm, so you can judge the adjustment needed. 6. Try feeler. 7. Tighten with feeler still in. 8. Try feeler while it's still in. Since it's tough to see, I use the endoscope to see the feeler is sitting correctly and all the way across before moving to the next cylinder. With experience I doubt this will be needed. End. |
Analog Air Cooled
I did a write up on doing mine last year. Search my name. I used the Stomski tool and a quick jack.
No leaks on the covers and all good 5000km after. I put a towel on the manifold and moved the comp there. No bigggie. http://forums.pelicanparts.com/porsche-911-technical-forum/1086634-how-my-valve-lash-job-led-my-exhaust-how-awesome-mag-induction-works-rust.html
86 Targa 91 964 13 6 SPD Cayenne Last edited by Hotshot; 10-26-2021 at 12:51 PM.. |
It's a fiddly process and certainly a bit intimidating the first time, but I think it's a rite of passage if you want to work on these cars.
I tried a bunch of different methods, but the original feeler gauge between the rocker and valve is the best in my opinion. I ended up purchasing a couple different stubby flat head screwdrivers and sorting through a few different box end wrenches. Some combos work better than others. |
YUP, suggest learning the real way first. Get jiggy later when you have the concept sorted. Not that hard really.
Now if I could only find one of those old school feeler gauge holders... |
