timing on a 3.2L with Carbs
I have a 3.2L with PMO's. Stock EFI cams (converted from EFI to PMO) and stock EFI pistons. This is a US spec motor (1984).
I am still researching timing curves. Any harm in going 32* advance at 3400rpm this would be max rpm. I have a 123 distributor I can program. Currently, I am 7* at idle and max 27* at 3400 rpm. Thank you in advance. John
John- 78 Slick Top 930 "Illegitimi non carborundum" |
Good morning. Any suggestions from those with experience with this?
Brew Master
I'm sure Gordo2 will be chiming in as this is something he played around a lot with. But you might consider a dyno day to get things really dialed in. I know it helped Gordo with his setup.
He's running a different cam, different ignition, and has JE pistons in his car so his setup is different from yours.
Nick Last edited by cabmandone; 02-01-2022 at 04:20 AM.. |
Thanks Nick. I haven’t gotten to that point yet. There are some carb tuning issues going on right now that I am working through. I was running lean on acceleration but was able to improve that by pulling timing. The flat spots due to lean mixture are in the midrange. I am mew to carbs on these cars but working through it and learning. Lots of reading and experimenting.
Brew Master
I'll tell Gordo2 about your thread. He has done a lot of carb tuning. Good info in this thread.
http://forums.pelicanparts.com/911-engine-rebuilding-forum/821976-gordos-pmo-carb-tuning.html
Nick |
Thank you Sir!
PMO with XDi
As Cabmando mentioned, I'm running a 3.2L with PMO's and Electromotive's XDi ignition.
I've found ~33° total advance provides best performance (for my engine config), adding most of the advance early / lower RPM range. XDi lets you adjust idle to 3k RPM advance and 3k on up. Here's a link discussing some ignition tuning: http://forums.pelicanparts.com/porsche-911-technical-forum/884610-dyno-results-gordos-3-2l.html My engine build is rather conservative WRT cam profile and pistons which comes in around 9.4 compression ratio. The lower CR & moderate cam allows me to play with things like ignition timing with less concern of pre-ignition (as compared to a higher CR engine). Technically this config would also allow running lower grade / 87 octane fuel - but I run higher, since I tend to play with timing and other setting often. Good luck, Gordo
Don "Gordo" Gordon '83 911SC Targa |
Thanks Gordo. I think have read some of your stuff. I will review it. I too am running a conservative setup and running 93 octane.
Brew Master
John,
What are you using to determine you're lean or rich? Do you have an AFR gauge? Don has an Innovate LM1 or 2 (I can't remember)handheld. I use mounted setup made by 14Point7.
Nick |
I have an LM 1 on the car. When it goes flat I can see that I am lean 16-18:1 ratio.
Here is a good curve to start with for your 3.2 with carburetors.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
Interesting thanks! I was close. I have tried multiple scenarios some off some close. Perfect and using a 123 Dist!
![]() Quote:
I think the most important thing I’ve done is install an AFR gauge.
