Your making great progress and everything looks good.
While your doing this, I would install a lower temperature fan switch which starts the fan running around 200F. This allows the cooler to stay ahead of the heat load. The factory switch has the fan starting at 244F. This is too high for me.
Nasson - Post 20, Front Oil cooler fan troubleshoot
BMW - oil cooler fan t'stat and switch installation
Old 02-11-2022, 08:04 PM
Antomero's Avatar
My oil cooler never had a fan. My Carerra is an 84 not sure when it went in production on later model years
Old 02-12-2022, 09:28 AM
Antomero's Avatar
I’m glad to say that I found extremely little surface rust after removing the fender. I went ahead and used 300 grit sandpaper to remove the surface rust. Not bad for a 36 year old carrera. The previous owner really babied this Porsche.
I’m going to bubble wrap the fender really well and ship it off to Shaun at True 6 Restoration to have it properly repaired.
I will continue to keep you guys up to date as I move along.
Old 02-13-2022, 06:24 AM
Antomero's Avatar
If you ever need to ship a fender or a bumper, try your local bike shop for boxes. The box was almost the perfect size for the fender. Lots of bubble wrap and tape. And off she goes. I hope the fender makes it over to Shaun it in one piece.
Old 02-14-2022, 05:23 PM
Antomero's Avatar
Update:: My OCD continues and so I decided to remove my spring plates and complete hardware and have Shaun once again do his skillful work. I was also considering painting the fender wells since I have everything apart. The paint has faded. What do you guys think? Should I leave it original?
Old 02-20-2022, 05:28 PM
Antomero's Avatar
Old 02-21-2022, 06:27 AM
donbecker1234's Avatar
Not sure if I missed it, but did you rebuild your thermostat?
I replaced the inner pieces of mine, and someone on here sells hex caps so you can service it more easily in the future.
http://forums.pelicanparts.com/porsche-911-technical-forum/792735-external-thermostat-rebuild-yes-i-have-searched.html
http://forums.pelicanparts.com/porsche-911-technical-forum/534387-oil-thermostat-rebuild-set.html#post5272278
https://www.early911sregistry.org/forums/showthread.php?127200-FS-Remote-Oil-Thermostat-Press-Relief-Cap-916-107-276-00&p=907365&viewfull=1#post907365
1987 M491 Widebody, Nautic Blue / Linen with a 1979 930 3.3L Cali Engine
Old 02-21-2022, 08:52 AM
You are certainly going above and beyond for most projects. Nice work. Are you planning to actually drive the car in rain or highway use? If so, just leave the fenders alone. If you are just going to drive to cars and coffee and occasional dry day only duty have at the fenders.
Great job on your project.
Old 02-21-2022, 09:34 AM
Antomero's Avatar
I just cleaned the hard brass lines and the thermostat. The thermostat was in good working order so I left it alone.
Old 02-22-2022, 05:33 AM
Before you reassembly, don't forget to blow out all the lines with compressed air.
Bill
1987 Marine Blue 911 Carrera Coupe RIP 01/2011
1987 Black 930 RUF Coupe Resurrected, 2488 lbs, EFI Technology, UMS Tuned - Mild & Wild, Current in pieces at paint
Old 02-22-2022, 07:21 AM
And maybe some solvent to get any grit or bad stuff left behind. And be super careful with the threads. They are really fine, and super easy to cross thread.
Old 02-22-2022, 08:09 AM
Antomero's Avatar
Will do.. thanks gentlemen!
Old 02-22-2022, 09:55 AM
Antomero's Avatar
Anyone use this product for the Porsche cavities?
Old 02-22-2022, 06:23 PM
Antomero's Avatar
This project has been really testing my new found skills. Last night I had some free time and decided to clean the rocker panel on the driver side since I removed the spring plates to have them reconditioned. Under all the dirt and schutz there it was RUST on the lower driver fender. Almost in the same spot as the passenger but not nearly as bad.
So this afternoon I removed the driver side fender and I’m glad I did, because the stone guard above the strut tower was being eaten away by contact surface rust.
After removing the stone guard on the inner lower driver fender it was evident the rust has been eaten way at the metal for some time. So it was my duty to make sure the rest of the Porsche had no rust. I spent the rest of the afternoon looking for rust in every crevice. Now I’m confident to report there’s no other rust to fix.
Apparently Porsche front fenders are common for rust, since the stone guard wears off after all years. So keep a look out for rust on your front fenders guys!
Driver side fender will also be sent to Shaun at Tru 6 restoration for the repairs.
I will continue to keep you guys posted on my progress!
Old 02-24-2022, 08:56 PM
RDM RDM is offline
Coram Deo
RDM's Avatar
Well I guess that answers your question about wheel wells....
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio
Old 02-24-2022, 09:38 PM
Antomero's Avatar
Anyone know the orientation of theses rubber grommets?
21 and 22.. do they go inside the fuel door or on the outside?
Old 02-25-2022, 05:43 AM
You might want to look at a product called Everbrite to keep those beautiful brass oil lines nice and shiny for a long, long time I use it on polished aluminum trim and it keeps a shiny for quite a long time
Thanks, Rick
Old 02-25-2022, 05:26 PM
Antomero's Avatar
Thank you!
Old 02-25-2022, 07:29 PM
Antomero's Avatar
Thanks, Rick
Will surly give Everbrite a try!
Old 02-25-2022, 07:30 PM
Antomero's Avatar
Greasy fingers inspired me to restore my wheel well housing since I essentially have everything apart. Wheel well housing have been painted in the original single stage paint formula. Very happy with the results!
Old 03-01-2022, 12:26 PM
