Targa Top Rear Pin Covers
I've read that these are referred to as "Silentbloc" pins or bearings. I don't know for sure. Anyway, the plastic covers for mine have cracked and broken up over time leaving just the exposed metal pins. While they do secure the rear of the top in place, they don't provide the proper tight fit given that the plastic covers are now gone.
I've found a part here on Pelican - 911-565-217-40 (Covering) that shows to be the right part on models earlier than 1987. Anyone happen to know if the part above will actually work on an '87 model? Thanks. Last edited by Ironman88; 02-05-2022 at 07:20 PM.. |
I believe they didn't change all the way up to 1989. I'd have to go research again but there is special method for installing them as well. I have a set that I still haven't got around to installing. I'd contact Dan Petchel (Google Targa Dan Cars Inc). He's the targa top guru.
Driver
Slodave gave me some surgical tubing that he used while rebuilding his top. Maybe not OEM, but it does the job.
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa |
I went ahead and ordered the covers from Pelican. I read that they can be a little bit of a challenge to install. One comment mentioned putting them in the microwave for 15 seconds or so and that made them pliable enough to install over the pins. I'll make sure first that they fit properly into the receptacles in the targa band and then if so, I'll go the microwave route. Hopefully no drama to follow... |
No probs. You're right, it's either microwave or boiling water. Maybe a really long socket or similar to tap them into place over the pins. The surgical tubing idea is great!
I used boiling/very hot water - let them sit in it for about 5 minutes or so. They will be much more pliable and should slide on rather easily.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
Not sure this is necessary, but I made a small hole in the tip to vent any trapped air. Maybe overkill, but didn't do any harm. That plus hot water worked for me. The new covers resolved a few squeaks I had
Good information - thanks.
