49willard
Location of trans seals
The attached lists part #4 as 3 locations for a Carrera. Can someone tell me the 3 locations? When I disassembled mine I had 2 of the #4 seals either side of part #13, the clutch release lever.
Bill 1961 356B coupe-long gone! 1986 Grand Prix White Cabriolet Last edited by 49willard; 02-14-2022 at 02:04 PM.. |
From recollection mine only had one left when I stripped and I concluded the others had broken up and disappeared over time. Use all three and place either side of item 13 and one below item1
The third shaft seal is inside the bellhousing by the release fork #1
49willard
Thanks Ian and Glen. That makes sense. On disassembly I had the 2 either side of 13 but no even pieces of a seal inside the bell housing.
Bill 1961 356B coupe-long gone! 1986 Grand Prix White Cabriolet |
