I would rather be driving
jpnovak's Avatar
Ultimate Shift Rod Bushing
I am reposting this out of my build thread. Someone suggested that I put this up there for those not following that project. Some of you could benefit from these.
Let's talk about shifting. I am running a 911/01 transmission mated to a 915 shifter that has had the guts rearranged. Basically, I flipped everything around so the R lockout was left-forward rather than right-rearward. I think added a Seine Gate shift and all was good. Except, when it wasn't and I kept nicking R on the 1-2 shift.
I tried everything and the reality was, the center of the gate shift was more precise than the rest of the linkage all the way down the line. The shift coupler already had the bronze bushings installed. That is not the culprit. The only place in the shifter assembly was the shift rod support.
in my opinion the shift rod support bushing is a weak spot in the system. Improvements are available for the shifter assembly and universal joint couplers are available. The two combined can nearly take all the play out of a 911 shifter. Except for the one weak spot right in the middle. So I fixed it.
I have been throwing this idea around for several years and finally put the effort to fix it. I made a new shift rod bushing. It is 30mm long, fits tight, made of modern, self-lubricating material and, fits in the stock location.
Here is a comparison of the new shift rod bushing compared to the stock bushing.
You can easily see the width. The external OD has a flange that mates to the forward edge of the stock bushing support bracket.
my new bushing is a press-fit into the bracket. The rear is secured with a circlip mating with a groove in the external surface.
What many don't realize is that the stock bushing has a radius along the inner surface and that minimizes the contact on the rod. There is a lot more play in the shift rod than most people realize. Once the new bushing is installed there is almost zero play. Just enough clearance to allow it so slide freely (front to rear and rotational) but without any of the off-axis play that plagues the stock bushing.
Here is a comparison of play between a new stock bushing (before) and an updated bushing.
After install there is a noticeable improvement in shifting quality. No more missed gear nicks. I am calling this the ultimate shift rod bushing.
An, while you are at the machine shop, might as well make some extras. I don't see myself replacing one anytime in the next 10 years or so. These are available if anyone sees the need. There are already a few supporting shift rods in the wild.
Old 04-21-2022, 12:49 PM
Jamie, I love this Idea. Good thinking young man.
Now what do I need to do to end up with one of these gizmos
Thanks Ian
Kermit, 73 RS clone,
Just Part of the Team
Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark
Jerry Sherman ,Rob McGlade ,Donnie Deal
Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains
Old 04-21-2022, 01:11 PM
jpnovak's Avatar
Ian,
Send me an email and I can set you up with one.
Old 04-21-2022, 01:25 PM
How can I get one of these? I was thinking about replacing this bushing sometime this year anyways and would like to try one of yours.
Chris
'75 911s Targa
Old 04-21-2022, 01:42 PM
Sent
Ian
Old 04-21-2022, 01:45 PM
jpnovak's Avatar
Chris (And anyone else)
Send me an email or PM and we can get you on the list. Interest is strong and I am almost sold out of the initial batch. It will take me about 1.5-2 weeks to get materials and make some more.
Old 04-21-2022, 02:02 PM
I'll take one. Sent you a pm.
Old 04-21-2022, 02:21 PM
Dr J's Avatar
Sounds like a great idea. PM sent.
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged!
Old 04-21-2022, 02:38 PM
Brew Master
cabmandone's Avatar
What's the point in installing something if it isn't going to dry out and fail causing shifting issues and threads about hitting R when coming out of 5?
Nick
Old 04-21-2022, 04:09 PM
jpnovak's Avatar
Nick, Sounds like you have personal experience with this... Maybe you need one too.
I have sold all the initial run. Send me an email or PM if you are interested. I am going to run another batch. Guess I need to plan for more of these.
Old 04-21-2022, 04:12 PM
Brew Master
cabmandone's Avatar
I have indeed. I'll let the future owner of my car know about the product. Nice work btw.
Nick
Old 04-21-2022, 04:17 PM
Uncertifiable!!!
Uwon's Avatar
Jamie, Wow, great mod. I would love to buy (3) three from you and mail them to my friend in PA.
I’ll send details by email.
TIA
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 04-22-2022, 04:27 AM
66 911 #302694
Arctic Rat's Avatar
Interested, PM sent
Joe D
My life is not a journey to the grave, with the intent of arriving safely in a pretty, well preserved body, but rather I will skid in broadside, thoroughly used up, totally worn out, and loudly proclaim .....
WOW WHAT A RIDE!!!!!!! reaperwear
Old 04-22-2022, 04:28 AM
Looks like acetal copolymer? Or delrin.
Old 04-22-2022, 05:02 AM
jpnovak's Avatar
Yes, Its a Delrin based polymer.
Old 04-22-2022, 10:23 AM
(man/dude)
Jonny042's Avatar
I scooped up three! Two for me, one for a fellow Pelican.
Great idea and execution.
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 04-22-2022, 03:29 PM
Bill Verburg's Avatar
I did the same thing ~20yrs ago, still works great
Bill Verburg
Old 04-22-2022, 03:31 PM
nice work!
Old 04-22-2022, 07:37 PM
@jpnovak I'm interested in one but am unable to send you a PM.
Old 04-22-2022, 09:34 PM
tobluforu's Avatar
What's the price, or did I miss that?
Old 04-23-2022, 04:05 AM
