dw1 dw1 is offline
R&D guy
dw1's Avatar
Location: the border between the states of inebriation & confusion
Yes, these mounts breaking are a common problem. I had the improved mounts welded into my '87 a year or so ago.
What is it like to drive without the rear bar? I thought about temporarily removing the rear bar on mine, but even with one side broken there was quite a bit of body roll and I certainly felt more of the rear weight of the car.
Thanks for the very nice write-up & photos - you've posted quite a bit of good information. Btw, I really like the interior & exterior color (alas, mine is black/black).
And I'm sure Hershey is a big help.
Old 10-04-2022, 02:34 PM
ZAMIRZ's Avatar
Where are you in the Bay Area? I'm down in San Jose and have an '83 SC Coupe in slate blue metallic (older brother to your car). Ping me, we should meet at Alice's some time.
Amir
'83 911SC
Old 10-04-2022, 02:44 PM
Dixie Boost Hooligan
turbo3six's Avatar
Congrats on your Venetian Blue Carrera! Is it 35U or 36P paint code? Both are Venetian Blue, but they are different shades of blue.
My 87 is 36P
72 911 T 3.0 / 73 911 3.0 turbo
74 BMW 2002 TI
79 930 / 84 911 Turbo / 2010 Cayenne GTS
87 911 Carrera Coupe / 87 911 Turbo
94 911 Turbo 3.6 /17 911 Turbo / 18 GT3 / 22 GT3
Old 10-04-2022, 06:14 PM
Absolutely gorgeous car, and great shot of it.
Bill
My 87 is 36P
Old 10-05-2022, 06:46 AM
I'm in Mountain View. I love Alice's, Highway 9, Highway 17, and along the coast. You'll see me at the Menlo Park Cars and Coffee (James Artist) sometimes too if you go there.
It drives more predictably without the snap oversteer. It is definitely more "floaty", it digs in and handles the turn well, but with a lot of roll and you need to load the suspension more.
Thanks!
My 87 is 36P
It's a 35U, I've always wondered about the side decal and ducktail on my car. Now I know what it looks like! Looks great. Thanks for sharing.
Old 10-05-2022, 03:06 PM
Driving my car around without the rear sway bar is not as bad as I thought.
I spent time realigning the sunroof height. Corner balancing these is a pretty simple process with the gear teeth in the back and spacer threads up front.
Old 10-15-2022, 09:44 PM
New fan belt day on 11/8/2022. Rear sway mounts fixed and reinforced.
I deleted the AC belt because... It wasn't doing anything anyways.
I wanted to change the transmission fluid but that 10mm plug up top was tight! I'll need a different tool to break it open.
Old aftermarket vs new OEM
All spacers were in good condition.
Old 11-17-2022, 05:05 PM
Mr. Merk's Avatar
Marlin approves
Old 11-28-2022, 11:38 AM
Bill Douglas's Avatar
Dog is VERY pleased with how the car is going (and where it goes).
Old 11-28-2022, 08:37 PM
Just some updates: 3/7/2023, I decided to get the A/C fixed and that week my heater blower decided to go at the same time. So the car went to RMG Enterprises in Sunnyvale, CA for a full HVAC makeover and check up.
The car got: New heater blowers, R134 A/C conversion, HVAC switches replaced and repaired, windshield washer pump, intake valves checked and tightened (noisy... I adjusted them on the wayyyy loose end), fuse box cleaning and new fuses, hood struts replacements, missing exhaust stud and nut added, clutch bleed, and condenser blower replacement.
New windshield on 3/20/23 with OEM Porsche glass and seal with Exel Autoglass. The aluminum trim will be reused since they were just installed in June.
Compression test was at:
1: 195
2: 200
3: 195
4: 195
5: 200
6: 195
If you live near Sunnyvale, CA, I cannot recommend RMG Enterprises enough. Dan and Dan are experts at their craft, provided excellent communication, documentation, and service.
PHOTO GALLERY - 2208
Old 03-20-2023, 12:44 PM
famoroso's Avatar
Busting out the digital calipers for the front condenser fan replacement. Now that's precise! ;-)
Earlier in the thread, I noticed that at least your driver's side door pin switch is missing its rubber boot.
Lose those hazy H5 headlights (or, at a minimum, clean the inner lenses with alcohol and rice beads and replace the desiccant packs), as they were criminally negligent when brand new. Get a set of H4s (a used set JUST sold here this morning for $475) and add headlight relays and you'll be golden. Also, if you haven't addressed these issues, consider doing so sooner rather than later...
http://forums.pelicanparts.com/porsche-911-technical-forum/548209-added-fuses-relays.html
Beautiful car! I'll be up for Lüft. Hope to see it there.
Frank Amoroso
911 M491 / M470 coupes:
1987 GP Wht / Blk "Apollo"
1987 Gemini Blue / Blk "Gemini"
1989 GP Wht / Blk "Vents"
Old 03-21-2023, 07:43 AM
Driver, not Mechanic
PCA GGR is inviting folks to the Los Gatos Peet's this Sunday, just saying.
Old 03-21-2023, 11:49 AM
Share the details please!
---break---
I just got the car back from Exel Autoglass, who did excellent work. Now, I'm wondering if I want to get Exoshield to protect the glass from small chips. Thoughts on products like these?
https://www.getexoshield.com/
Exel Autoglass pictures:
Old 03-21-2023, 01:35 PM
shinrai's Avatar
Nice work!
I run Exoshield on one of my cars that has a very expensive and difficult to find windshield. It's a great product if installed correctly. It had to be done twice because the first fitment had an annoying horizontal line that changed the horizon on motion. I imagine 911 windshields will always be easy to source so maybe not needed.
'87 911 GP White "casper"
'97 Esprit V8 "flat eric"
'97 993 Speed Yellow "tbd"
Old 03-22-2023, 05:57 AM
famoroso's Avatar
Originally Posted by shinrai View Post
Nice work!
I've had Clearplex on my Lotus windshield for years, with 100+ track days and it's been invaluable.
On 911s, I don't think it's as much about windshield availability, as it is about preserving an existing known good / leak free install. The whole windshield install thing has become more art than science, including sourcing the right seal and searching out the local shaman, I mean installer.
Frank Amoroso
Old 03-22-2023, 06:27 AM
Frank,
Can you PM me your local windshield shaman info?
Thx
C
Old 03-22-2023, 06:45 AM
Ayo Irpin, Ukraine!
70SATMan's Avatar
Website says HMB. Los Gatos Peet’s appears to be out.
https://pca-ggr.org/event/ggr-cars-and-coffee-2/
I might take a run up on Sunday. My BIL is up there.
Harmlessly passing gas in the grassland away;
Only dimly aware of a certain smell in the air
Old 03-23-2023, 07:45 AM
Signed up for Luftgekühlt 9! I guess they'll take any car.
Clutch pedal was sinking occasionally. Master cylinder, hose, and slave cylinders changed out.
Old 03-24-2023, 10:40 AM
Originally Posted by boogieman065 View Post
Hi there!
I'd just like to document my guardianship of the car on one location so that it is easier to follow (#ritno88911 on Instagram). I picked up a 1988 Venetian Blue 3.2 Coupe on 1/30/22 after months of searching. This car is supposed to have a bit of a sentimental value to me. It is my birth year car and I am graduating with my master's degree the year I bought it! A little early graduation present for myself.
I have done a bit of work to it trying to bring it back to what I consider to be an acceptable daily driver. It is far from a concours car, I just wanted a quality/reliable car that I can add miles and miles of smiles.
The interior carpeting and upholstery were done right before I bought the car, but the paint/exterior was in neglected condition and the service history was largely unknown.
I'll update/backdate the progress on what I'm doing and what I've done so far. Please feel free to provide feedback and teach me all things air-cooled!
The two Facebook Marketplace posting images are below. I reached out to him the night he posted, after I test drove a 993 tip that day that I wasn't happy with. The seller of this G50 car had about 50 messages, I just got lucky somehow and saw it the very next morning.
Pre-Purchase Inspection at European Auto in Salinas, CA showed a clean bill of health. Leaky exhaust valve cover gaskets and tires from 2007. I got lucky and had a guy who used to work at Porsche of Monterey inspect the car. Even driving to the shop, I could tell that despite the neglected appearance, the 1988 911 drove much better than the 1994 I test drove the day before.
With my 2007 Cayman S in the background. The Cayman is a DD that has 135k miles and I've owned it since 2019.
Interior shot
Car looks great after the paint job. I’ve got a 75 S carrera that I’ve owned since 1976. Going to have to paint it again. What’s a full paint job run now? Just curious.
I still drive mine every day!
Old 03-27-2023, 02:19 PM
I had a friend's shop do it, total it was about $5k for parts and labor... That's pretty much at cost. He's retired since then, unfortunately. And he swore he will never do a Porsche that low again lol.
Driver quality respray with glasses and trims off are around $8-$20k
Old 03-28-2023, 10:28 AM
