Weather strip at doorsill lifting
Getting ready for a wash and shine I just noticed the weather strip on both doorsills are starting to lift at the ends. What the recommended procedure to re-seal? Patch in place or lift the compete strip and reseal? What bonding agent is recommended?
Tom, check out this thread. Should answer your question. http://forums.pelicanparts.com/showthread.php?threadid=109166&highlight=3m
Dan T '85 Carrera Dansk premuff/sport muffler 7's and 8's, Steve W chip Kuehl AC and fresh top end |
Tom,
Are you referring to the foam surround that completely goes around the door? I just redid both of mine and it's not that bad but getting all the old glue takes some time. Use the 3M Adhesive remover. Also, 3M makes a highly recommended weather strip seal that comes in a tube and is black, which helped since it tends to get where you don't want it a little bit. The adhesive remover will get off any mistakes though. Good Luck
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
Thanks guys this helps. I was actually talking abut the approx 2inch wide rubber strip the length of the door opening that is on each door sill. I'll try that Wurth Rubber Glue.
