Which stapler will work
I am going to staple inside door panel to the "wood" door card. Which stapler is suitable to do the job...of course don't want staples to come through and don't want to spend a fortune on a stapler.
Old 07-25-2022, 03:13 PM
great thanks
Old 07-26-2022, 08:25 AM
I used a Porter-Cable 5/8” (the width of the staple top) Upholstery Stapler Model #US58, it’s the pneumatic model. Costs about $100 but I’m sure there’s cheaper ones available including some hand operated ones, which these are only good if you can get good steady pressure on a firm table/surface.
Make sure and measure thickness of both backer and material and use the proper sized staple, they come in varied lengths.
Old 07-26-2022, 12:46 PM
Discseven's Avatar
$19 is likely as econo wood puncher as it gets. And this takes a range of staple lengths.
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 07-26-2022, 01:24 PM
bought this one
hope it works! worry about staples coming through the door vinyl.
Old 07-26-2022, 06:01 PM
which size staples would you recommend to attach inside vinyl door panels to the door card?
i believe these are 3mm thick.
Old 07-26-2022, 06:12 PM
staple size?
i bought this stapler you c recommended.. which size stapes should i use ??
Old 07-27-2022, 10:57 AM
Diss Member
Quicksilver's Avatar
The problem is that 1/4" staples are too long. You really need 5mm or 3/16" staples and those hard really hard to come buy.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 07-27-2022, 07:34 PM
Heck, I’m only 5 not 71!
targa80's Avatar
The leather was one whole piece. It does not require glue to install, only staples on the backside edges where the leather wraps around. I used 1/4 “ staples and they came though the other side of the backer board. The original staples are a hair less than 1/4” and the replacement staples are 1/4” but the new padding covers the protruding staples tips and are not an issue with the leather. The thread on replacing door backer board is below.
https://forums.pelicanparts.com/porsche-911-technical-forum/1025491-replacing-door-panel-backer-board-cheap.html?highlight=Door
Pat Henry
Targa80
1980SC Targa (Mocha Brown)
Old 07-28-2022, 03:56 AM
looks good!
you did a nice job...got the same thing going on..and more. Decided to paint the doors while they are stripped, along with the mirrors and power coated the handles.
Old 07-28-2022, 12:40 PM
Discseven's Avatar
Is based on the materials that you're working with so only you can sort that out. This stuff is always a matter of testing to determine the "best fit." Maybe you want to bend the open ends of the staples over in which case long ones will be called for. Might be once the staples are in the board, that bond alone is sufficient... and so short staples. Test...test...test.
Karl ~~~
Old 08-02-2022, 01:33 PM
