911SC Targa door adjustment question
Hello,
I have a fallow up question to my other post.
After having the targa top rebuild, the new targa top seals are thick. When i close the drivers and passenger doors, the windows are too high wnd dont fall under the seal. The window is outside the seal as you can see in the picture
Where don i adjust the door height (picture please), so when i close the door wirh windows fully up, it slides into the proper position under the targa top seal?
It needs to be adjust by 1/4” to 1/2”
Old 09-16-2022, 05:37 PM
berndtj's Avatar
I’ll try and find a link, but you need to remove the door cards. Then lower the window maybe 1/5 of the way and you can see an Allen head screw through one of the holes. Loosen the screw and move it forward/back to adjust the window max height. Just did this earlier this week.
Old 09-16-2022, 07:43 PM
Your window appears to be riding up too high. The top edge should be even with the top of the vent door frame. This means that the overall height of the window is too high.
I have a PDF of the factory adjustment manual but can't seem to attach the PDF file.
1978 Targa - 1980 3.0; Carrera intake; Megasquirt 2; EDIS ignition; 22/28 mm torsion bars and late Carrera sway bars; Carrera front brakes. Targa top rebuild in 2017. Suspension rebuild in 2019. Needs new paint and interior carpets.
Old 09-16-2022, 08:27 PM
That would be helpful
Old 09-16-2022, 08:34 PM
PM me your email and I'll send it tomorrow as a PDF
Old 09-16-2022, 09:11 PM
Send a message via AIM to fintstone
Yes, way too high. You have probably torn through the rubber on the frame connection.
It should stop at the top of the frame connection (black rubber stop) at the top of the vent frame.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 09-16-2022, 09:32 PM
More like this:
Old 09-16-2022, 10:05 PM
Torn
Window stopper is torn
Hope its easy to replace
Old 09-17-2022, 07:49 AM
Not really, you have to pull the window frame from the door and remove channel, take apart, drill out rivets, press new ones in with new corner piece.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 09-17-2022, 08:12 AM
Temporary fix
I did an ugly temp fix
Old 09-17-2022, 08:59 AM
Looks good. They are a pain to replace. I just replaced both mine. That is why they look new. Waited until I had it apart to do the other seals. They all end up tearing eventually.
Did you get the info on sealing your Targa? If not, PM me with an email and I will send a couple PDFs.
Old 09-17-2022, 06:06 PM
Thanks, i did get the info
Old 09-17-2022, 10:18 PM
[QUOTE=berndtj;11799364]I’ll try and find a link, but you need to remove the door cards. Then lower the window maybe 1/5 of the way and you can see an Allen head screw through one of the holes. Loosen the screw and move it forward/back to adjust the window max height. Just did this earlier this week.
@berndtj - I'd be interested in that PDF, also.
Old 09-20-2022, 08:02 PM
ROW '78 911 Targa
timmy2's Avatar
https://www.dropbox.com/s/bbew4u10ax7f8ez/targaroofrepairs.pdf?dl=0
Targa roof manual
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 09-20-2022, 08:45 PM
