911SC Tinkerer
AFR and Fuel Tables for a NA 3.0 SC?
Hi Pelicans,
I’m wondering if anyone has an .msq they can share for tunerstudio or their AFR and Fuel tables. This is the set up I will be using: *1983 911SC Normally Aspirated stock bottom end, heads and pistons *MS3Pro EVO ecu wired to run in batch fire with Denso coil on plug ignition (standard 36-1 missing tooth wheel) *27lbs/hr @40psi injectors *Newest release of Tunerstudio I’m not confident the .msq I was using with the previously installed MS2 ported over correctly and I’d really like to avoid starting over from scratch. Thanks Guys and Gals! -Steve |
