Looking for Part #
Anyone know what the part number is for these plastic sleeves that go over the metal tie downs for harness wires on a G-body? Thanks!
I don’t believe there is a part number for those. Might want to pm timmy2.
use regular heat-shrink..
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Thanks for the great suggestions!
That is available from many places and you can cut your own.
It's just 3/8" PVC hose sleeve. Can't seem to find the threads on it or the part number (it exists I believe, but the part is listed for another purpose). Can't find it here on Pelican. Use your old one as a template. |
ROW '78 911 Targa
1/4 or 3/8 (depending on year and width) PVC vinyl tubing with a piece cut out in the middle to clear the weld.
Where can I find some 3/16" PVC vinyl tubing all I can come up with is hose
Lorne M.
83 SC |
Did you check Mcmaster Carr?
found it uxcell Black PVC Tube Wire Harness Tubing,
83 SC |
