911 striker plate
Just bought the striker plate kit with white plastic parts, and gasket that goes against the door jamb. Is this a difficult job? Is there a lot of tweaking to get the proper click?
I'm using original parts, other than rebuild kit. Thanks
Old 11-22-2022, 06:49 AM
One pin to drive out, then rotate one half of the assembly to get the new pieces in. I think a vice or large c clamp is needed for this job. Not hard at all. You do need the right bit (star?) to remove the striker from the car.
Old 11-22-2022, 07:18 AM
Fairly easy to do. If the striker bolts are not rusted in place.
You can lube them from the backside in the wheel well prior to loosening.
Old 11-22-2022, 07:36 AM
Easy job. To maintain door adjustment and find the proper "twang," outline the striker plate with a pencil on the door jam. That way you can at least start from where you were. If you don't have what you want, loosen the bolts & tippy-tap with a hammer to move the striker plate around a little bit.
Find the correct "star" socket before you start. The set is pretty cheap at Harbor Freight.
Old 11-22-2022, 08:21 AM
Awesome advice, thanks guys!
Old 11-22-2022, 01:17 PM
You drive out the two small pins then rotate the assembly.
Old 11-22-2022, 01:23 PM
Prope bit to remove plate is an M8 Triple Square.
Old 11-22-2022, 02:37 PM
I fought to get the old pieces out. It wouldn't swing open. Finally got it to swing open, but there is no way with new plastic pieces in place, I can get it to swing shut. I removed the two pins, lubed it up good, but the plastic is so thick, I can't get it to close up. Parts are correct. What am I doing wrong? Thanks
Old 11-25-2022, 05:11 AM
Dirt/ grime/rust/ bead blasting can make the assembly difficult to rotate. I soak them in a mild acid before plating and they rotate easily. Try cleaning the pivot area either ultra sonic, or a solution that won’t damage finish if your not replating.
Old 11-25-2022, 06:21 AM
It swings very freely, the problem is getting it over the brand new thick plastic, where the mounting screws go through.
Old 11-25-2022, 06:32 AM
Sand it
Old 11-25-2022, 06:47 AM
I can't get the barrel over the plastic. Do you have to put in vice and just force it???
Old 11-25-2022, 07:52 AM
I figured this job job would have been easy task, but now I see that’s why they offer complete striker replacement units. Looks like plates need to be pried up ever so slightly not to deform them then rotated back into final position. Did you see this post…
http://forums.pelicanparts.com/porsche-911-technical-forum/806739-plastic-pieces-door-striker-plate-replaceable-2.html
Old 11-25-2022, 08:24 AM
Designer King
Paulporsche's Avatar
Can't you rotate the top steel part so the downward bump in your pic is over free air, put the plastic in under it and then rotate both the plate and the plastic back into position? Actually, you may want to invert everything so that bump is facing upward and you drop the plastic onto it.
It's been a while since I did mine so I don't really remember for sure.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 11-25-2022, 01:44 PM
mine went just like this video, super easy
https://www.youtube.com/watch?v=KVInAg3_KIA
Old 11-25-2022, 05:07 PM
Dr J's Avatar
I did it about a year ago and don't remember it being particularly difficult. The whole process took me a half hour start to finish.
Can you double check you got the right part? Compare the new piece to the old one as yours looks too thick. If here is nothing left of the old, compare to the striker on the other side.
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged!
Old 11-25-2022, 05:24 PM
Where did you get that kit from? Plastic looks different and it’s too thick.
Old 11-26-2022, 06:32 AM
