CPT KAOS
Door speaker recommendation
Ok audiophiles. Help a brother out. I currently have a set of Focal VS130 5.25" components in my doors and some crappy old kenwoods in the package tray. I am lightening the car but still want some tunes for long trips. The package shelf speakers are going away (unless you persuade me otherwise) and i am thinking I could go to a larger set of front components, like a 6.5" main.
Thoughts? Anybody want some nice 5.25's? Thanks
Erik- RGruppe #743 Sports Purpose Garage CPTKAOS 313HP/265TQ(wheels)2150# |
i just redid my whole system. i went on ebay and searched for the most expensive car speakers. focals, morel, jl's and a brand ive never heard of.
critical mass- they are a 6.5 coaxial w/a carbon fiber woofer and a massive tweeter. you can get them for around 299 for two. i took a chance and bought a set. they are incredible, really shallow mount and the specs are great. 2" woofer voice coil 1.25" tweeter voice coil. i bought another pair and stuck those in the back. they are worth checking out critical mass rs6
Jason 81 SC 97 328is 87 Jeep Comanche (RIP) |
Administrator
-Dmitry |
Both suggestions above are great speakers. I went with Alpine 6.5" separates in the doors and a Focal iBus 2.1 powered sub under the passenger seat that ALSO has a built in 2 Chanel amp for the separates. Absolutely awesome in this car. I also put some 4x6 alpine coaxials in the rear shelf just for fill (it is a targa after all). The rears are powered from the deck and everything is balanced to produce good imagining. I managed to get the stock grills on the back too.
84 911 Targa Carrera currently getting renewed |
Just go with the 6.5" Focals. These things rock. I removed my rear speakers and sub woofer and just run these Focals. They sound excellent.
Brew Master
I'm happy with my Alpine Type R's. I have them front and rear in my Cab. I need to get a more powerful head unit or an amp to power them though.
Vintage Owner
![]() These provide a nice flat surface for mounting the larger speakers. A member on this list makes them.
84 Targa (sold) 70 914-6 (sold) 73 914-6 2.7 conversion (sold) 75 GMC Motorhome (sold) 2016 Cayenne |
These work great ^.
There are also dimensioned drawings of the above boards. I think I made mine from them out of MDF or plywood. See this thread for drawing:
http://forums.pelicanparts.com/porsche-911-technical-forum/446716-6-5-door-speakers.html Dave
Dave McKenzie 1984 Carrera 3.2 1984 928S Automatic 2001 996TT Last edited by DaveMcKenz; 04-12-2017 at 07:40 AM.. |
911SC Tinkerer
If you're going to really do it and do it once, try to do it right.
I used Infinity Reference 6.5 components. I also sealed the door with dynomat style sealing roll (it was at lowes and really had no smell after install, think I paid $6-7 for a 16ft roll. I bought two and had enough left over to do the entire rear deck area).. This made the biggest difference for the audio quality. I did the inside of the door skin as well to reduce road noise. I paired the infinities with an amp rated to the max rms the infinities could handle safely. I also made spacers like the ones above out of 1/2inch particle board. It's not hard with a hand held electric band saw. The only two really painful parts were cutting into the door panel vinyl to locate the hole for the tweeter and having to rewire the window switches. PITA! I no longer need the rear speakers. The sound is amazing when I want it. For the most part the radio is off as per requests from my son "so he can hear the engine". -Steve
-'83 911SC Coupe SSIs, Dansk GT3, EFI ITB, Instagram: @ Zinnmetallic_sc |
Chain fence eating turbo
I like Infinity Kappa's over Focal's.
Morel's sounded great in a friends 965. |
Eng-o-neer
As this post was from a year ago, I suspect LeftCoastErik has found a solution or moved on.
I really like the Infinity series available through Crutchfield
The 6.5" fit nicely in the doors without any modifications or protrusions and allows for the factory grills. https://www.crutchfield.com/p_108R6532IM/Infinity-Reference-REF-6532IX.html?tp=105 ![]()
1983 911SC 1977 930 Turbo (again) 2018 GTS 2023 Audi A4 '74 914 '76 911S '72 911T '73 1/2 911T '77 930 Turbo (all gone) |
Those use the stock mounting holes and wiring connections?
1982 911SC |
Door speaker
As i remember, I am pretty sure i had to drill new holes for this size speaker.
There is a smaller 5.25" version that would likely not require any drilling . I used the stock wire connections
Senior Member
Focal with tweeter were 20 minute install in my office parking lot with crimping tool for the harness. I used JBL for the rear deck. I have a Targa, so high fidelity is shredded $$$s. Sounds great driving around town and blasts pretty good. Bass suffers, but I am not a "whoomp, whoomp" kind guy.
Chris 1988 911 Carrera Targa (driving project started JAN 2022) 1970 911E - Long since gone 1972 911 Targa - gone 1987 911 Carrera - gone Retired FA-18C Driver |
You will need some sound deadening. Made a big difference for me Sent from my iPhone using Tapatalk
Silver 1987 Porsche Targa Carrera Build thread: 87 Porsche targa! projects tracker |
Burnin' Rubber
Focals in the door and a sub under the passenger seat. Nice JBL amp drilled onto the passenger wood footwell backside.
Sounds terrific |
