Simple on/off toggle that replaces headlight washer switch?
I am looking for a simple on/off two-position switch that fits in place of the headlight washer switch. Possibly something from a 964? I thought I found it with part #964-613-325-01-01C-OEM from our host but, this is also a temporary switch like the oe washer.
Old 03-06-2023, 02:33 AM
Been here a while
There’s a rear wiper switch that will work.
I took apart my washer switch and removed the spring. This way it looks stock but functions as a toggle.
looking for 1972 911t motor XR584, S/N 6121622
Old 03-06-2023, 02:52 AM
Rear wiper switch is something like a 5-post switch. Good idea on the spring removal, I’ll give that a go.
Old 03-06-2023, 05:57 AM
Are you trying to use it as a kill switch? I wouldnt want the headlight washer running in just on off mode. That pump / wiring draws a lot of power.
Old 03-06-2023, 06:30 AM
Full Send Society
Get over to mouser.com or digikey.com and lose your mind over the thousands of options. You’re certain to find what you’re in search of and without any Porsche tax.
-Julian
1977 911 S: Backdate, EFI/ITB, AC project in the works:
http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html
Old 03-06-2023, 06:45 AM
7783911's Avatar
i suggest a 3 prong so its lit at night?
Old 03-06-2023, 08:58 AM
This ended up working perfectly, thanks!
Old 03-06-2023, 10:47 AM
shoooo32's Avatar
The power window selector switch appears to be the same size/style. I repurposed mine as a oil cooler fan switch.
-Tony
Instagram: @Pablo_the_Porsche | @RuchlosRallye
AchtungKraft #002
Old 03-06-2023, 10:48 AM
It is a large pump, and moves a lot of water and will hose down the entire vehicle.
Old 03-06-2023, 01:42 PM
