This. A good windy day may make that roof just leave.
I asked a local home builder friend about modifying my garage. I have a full sheet rocked and insulated three car garage. It would have been over 30 grand. I just dug a pit, and put in a scissor lift. I love it. When the car is out of the garage, and the lift is lowered, with the piece of plywood on top, it is basically gone. ![]() It is great as a work space for my lawnmower. I did hire a garage door guy to raise the door rails to the maximum height, and put in a new door lifter to gain some height. ![]() I have done several transmission fluid changes, and the tunnel fuel hose replacements. No it is not as nice as a real lift that one can walk under, but it works for my garage, and I love it. I would hire an engineer to look at your roof and be sure it is safe. Your insurance company may not like that roof as is.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Roy
1959 Bristol 406 (bought in 1972; sold in 1977) 1966 Porsche 2.0 coupe (bought in 1977; sold 1981) 1978 Porsche SC coupe (bought in 1993) |
Slightly Knowledgeable
Those cut rafters and the scabbed on pieces look exceedingly sketchy. I'm sure they would not pass any kind of inspection.
2009 Porsche 911 C2S, 2002 Porsche C2S (traded) |
Kent, what type of fasteners did you use to "reassemble" the parts after you made the cuts? Are they threaded or are those nails?
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
3" heavy screws. I may, this summer, cut off the short pieces and add them to the top braces this summer. Just a little more strength. Even though lifting the 750lb ramp of the 4 post lift, off my trailer didn't even cause a squeak from the roof.
Kent Olsen 72 911 SCT upgraded 3.0L McMinnville, Ore |
Screws are weak in shear strength.
Sent from my iPhone using Tapatalk Pro
Still here
Do you sit under that or crouch and isn't it in the way of getting to the midsection of the car ? Engine drops doable ?
Roy
PCA Member since 1988
Kent: Here are some building code considerations: The roof structure must be able to support the total load of a heavy snow on the roof. The typical design snow load requirement for a roof is 30lbs/sq.ft. The trusses on your roof look like they are 2 ft apart, so each truss must support a strip of roof 1 ft. on either side of it, multiplied by the length of the truss. I'll guess that at 20 ft. Thus each truss must support 2x20x30=1200 lbs. If you can support 1200 lbs hanging from the center of each truss, then your roof is strong enough. If your truss lengths or spacing are different, re-run the calculation with your numbers.
It still looks bad though, and any building inspector would flunk it.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
