1986 911 Diode for Running Lights, help!
My 1986 carrera has a dead diode just beyond the headlight switch and the part has been discontinued! Wehrle 911 617 108 00. Grey wire with red stripe. Running Lights.
Can anyone help find one of these? I have tried all the online resources and dealer, no dice. Thanks.
Old 02-04-2010, 11:30 AM
Tree-Hugging Member
Jim727's Avatar
I'd call these guys: SF Bay Area Porsche New & Used Parts || EASY - European Auto Salvage Yard
Welcome to the board!
Politicians should be compelled to wear uniforms like NASCAR drivers, so we could identify their owners.
Old 02-04-2010, 12:26 PM
i just remove it and attach the wires. haven't seen any issues doing it that way. i often wondered why it was there. why is it there?
206 637 4071
Formerly known as Syzygy
Canada Kev's Avatar
I know this might be a bit obvious, but with it being a diode, there is probably another (potential) source of electricity somewhere else in the circuit on the other side of it and they don't want it to back feed through. I have absolutely no idea of what it might be, though. What does it show on the electrical diagram?
Kevin
Old 02-04-2010, 12:42 PM
Checked out
McLovin's Avatar
It's a "mystery part" for which no one has seemed to come up with an answer.
It's odd because (1) it is ONLY on the '86 model year, which appears to otherwise have no difference in the wiring circuit from the other years, and (2) it is only one one side of the parking light circuit (pass side?).
Old 02-04-2010, 12:45 PM
Canada Kev's Avatar
Maybe the reason it's NLA is that it doesn't serve an actual purpose?
Kevin
Old 02-04-2010, 01:01 PM
Correct, when it goes out it only effects the Passenger side running lights. Weird. I had Jim and John at Easy climbing through all their parts and they found two of them for me and another guy that I am helping with the same issue. Thanks Guys.
Old 02-04-2010, 01:03 PM
Friend of Warren
It does nothing. Took mine out 6 years ago and everything continues to work as normal.
Kurt V
Old 02-04-2010, 01:46 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
Hm, the only diode I see is in the charging system of the 84' Carrera. And that is to prevent run-on when you turn off the ignition. Without it the alternator D+ can feed current back into Terminal 15 when you turn the igniton off.
Is there another one on a 86 that is not shown in the WSM (that I have)
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 02-04-2010, 09:05 PM
I had one side of my running lights go out on my 86 Carrera years ago. I had no idea that there was a diode. I just jumpered the two sides together and got all the lights working that way.
-Andy
Old 02-04-2010, 10:10 PM
34Carrera's Avatar
My understanding is that diodes are commonly used to prevent the voltage spikes that happen when a relay is de-energized (the current needs to go somewhere) from arcing across one's switch contacts. One can have 300V+ spikes from a 12V relay which can potentially wear out one's switch contacts over time.
http://www.aeroelectric.com/articles/spikecatcher.pdf
Old 02-10-2010, 01:03 PM
ischmitz's Avatar
An inductive load will produce a spike when a circuit is interrupted. That is how a Kettering ignition works. The coil induces a voltage spike to counteract the breakdown of the field.
This is why relays (or inductive loads in general) that are driven off a semiconductor have a diode across the coil to supress this spike. Modern automotive relays have these diodes built in and there is no need to add external diodes.
Old 02-10-2010, 02:37 PM
dshepp806's Avatar
there to reduce contact "chatter"....
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 02-10-2010, 05:54 PM
Diode Specs
Does anyone know the specs for this crazy diode? I just found out I need one. Thought I could find replacement at radio shack.
Thanks....
Sara
Old 02-11-2010, 11:58 AM
dshepp806's Avatar
Anyone know the spec on PIV (peak inverse voltage) for these diodes.....? (aside from it's current rating)
Doyle
Middle Georgia
Old 02-11-2010, 03:37 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Had the very same issue many years ago on our '86.
Our passenger side parking lights went out.
My factory circuit diagram showed the "usual suspect",
however finding it was an interesting search.
Using a multimeter, I found the diode to be open.
I bought an equivalent diode, and all has been well since then.
Just go to your local electronics store, buy the diode, and solder it
to the pc board.
I put two in parallel for redundency.
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 02-12-2010, 04:23 AM
Hi Guys,
Thanks for your quick responses....
I did order part #91161710601. The staff at PorscheOEM in San Francisco
said I could interchange the parts.
What do you think?
Thanks again...
Sara
Old 02-13-2010, 10:07 AM
News Update:
I just learned that Classic-Service (Porsche factory parts for the old guys) is bringing back the diode. You will again be able to order this "unique" PITA part from the dealers. I still have not heard from ANYONE why they put the diode in the circuit, but I am sure it has to do with voltage flowing in the wrong direction and illuminating the bulbs.
Old 11-08-2013, 11:48 AM
I found this same part: 911.617.108.00 in my 1983 SC while removing the aftermarket (Hofco III) alarm system. It was attached to the wiring just behind the passenger side frunk hood strut. The wiring connects into the hood open/close sensor that triggers the frunk light. I don't know why it is there, but I removed it.
Looked up the part number and came across this thread. A few posts above indicate it is for 1986 Carreras only, not before. But this is an interesting case (exception?) in an 83 SC.
I hope my front passenger side marker will still work w/out this diode.
1983 911 SC Coupe w Sunroof, Metallic Silver --- AKA 83 Silberpfeil
Old 05-31-2023, 08:46 PM
