Is the fuel pressure test port removeable?
Of course, everything is removeable. I mean is it separable from the fuel rail? Looks to be all one construction. The thread on mine is partially stripped so it would be better if I replaced it. If separable does anybody know the part number or spec?
Apologies to whomever I nicked the photo off.
Old 06-10-2023, 06:42 AM
I dont believe so, its 1 piece. Im showing:
930 110 307 04 Fuel collection pipe as the part for the whole rail.
Old 06-10-2023, 10:12 AM
Much obliged to you. Looks right, pics show the port is part of it.
Old 06-12-2023, 10:30 AM
Still here
pmax's Avatar
I'll be surprised if that fitting wasn't bolted on .... tight.
Only one way to find out unless someone knows for sure.
Old 06-13-2023, 12:50 PM
There is currently an adaptor to the black pressure gauge line that is installed on the port, but the port itself is part of the fuel rail.
I don't know how bad your threads are, but provided the cap will tighten, it may not be an issue. the threads don't create the seal, there is a 9mm ball bearing the actually creates the seal under the cap.
Old 06-13-2023, 01:14 PM
Got a cap right now on an 89 that won't budge. Butane torch heat, beeswax, no go. Really would like to check pressure but if one reefs on that cap too hard, the fuel rail will be tweeked or ripped open. Be careful with your strength.
206 637 4071
Old 06-13-2023, 01:33 PM
Stubborn Test Port Cap……..
John,
Did you try a pneumatic impact wrench @ moderate setting? Then subsequently increase the torque as needed. No breaker bar unless you’re willing to take unnecessary risk.
Tony
Old 06-13-2023, 03:12 PM
No room for an impact wrench down there unfortunately.
206 637 4071
Old 06-13-2023, 03:37 PM
