leak from spedo sensor cavity?
I've got a 85 915 transaxle with a oil leak that I'm trying to track down. It only leaks when running, so it's above "the water line". It'll put a few drips on the garage floor after a drive and not another drop for a month. I've cleaned it and run it for 30 minutes. Sure enough, it leaking..... but from the speedometer sensor!! Ya, I know, that sensor sits in a blind cavity! Anyone ever heard of a crack in the spedo sensor mount??
As always, Thanks for the help!
Gord. Scotch Village (near Halifax) Nova Scotia, Canada |
That's very odd, from changing my own speedo sensor recently, I too realised its in a blind hole, not sure why there would be crack there, unless someone's been a bit ham fisted getting the old one out at some point.
Let us know what you find. Ant... Quote:
"But instinct is something which transcends Knowledge We have undoubtedly certain finer fibres that enable us to perceive truths when logical deduction or any other wilful effort of the brain is futile" Nikola Tesla |
PCA Member since 1988
The question to cover the other possibilities: Did you smell it and verify it's tranny oil and made sure it's not coming from somewhere else? Otherwise, I'm stumped too.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Reach up top and feel for the hole in the breather fitting. It needs to face the front of the car.
You can pop the speedo sensor out to check for a crack. Very thin there.
