What not to do when building an engine.
My customer bought an engine 3.6L built with RSR cams. It froze up 3000 miles later and he brought it to me to tell him what went wrong.
Too much silicone being used everywhere.
Note the excessive use of black silicone filling up the rocker shaft holes making it impossible to now remove the rockers.
Bit of silicone broke off blocking oil passages leading to oil starvation which spun the number 3 rod bearing and likely bent the crank.
Whoever did this had no business building engine.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 06-21-2023, 05:31 AM
walt's Avatar
When you think you have seen it all.
Walt
82SC 3.0
81SC 3.6
Old 06-21-2023, 05:38 AM
1978 911 SC
Looks similar to the "NEW REBUILT" engine I purchased from forum member couple months back.. Everyone claims to be engine builder these days... great picture showing what not to do. Crazy.
1978 911 SC Complete rebuild, 83 engine, SSi’s M&K Sports muffler.
Old 06-21-2023, 06:22 AM
Where does the mindset of using silicone everywhere come from? Do people just naturally assume since they used silicone caulk on their shower that they should use it in other places for sealing?
Those rocker shafts make me want to puke.
1982 911SC
Old 06-21-2023, 06:26 AM
al lkosmal's Avatar
rebuilt engine
Seems to be going around.....here's some pix of the rockers on a 3.0 that was sent to me to figure out why it was making bad, banging noises......
The 1st pic shows the same use of silicone to seal the rockers.....will be a beeeyatch to get those out of there......also some sticks/sawdust stuck to the gasket......but the 2nd pic shows the winner....pistons installed rotated 180 degrees out. Pretty sure that is the cause of the bad noises.....
RGruppe #669
http://www.x-faktory.com/
Old 06-21-2023, 07:22 AM
Yep same wonkiness going on with this 3.0. Besides loving red RTV and using lower allen bolts instead of studs I just uncovered this:
83' Coupe - Ex-RaceCar
77' Targa Narrow Body - SC powered
Copper Brown Metallic
Old 06-21-2023, 07:26 AM
proporsche's Avatar
we have some schmucks here in Czech too;-)
1985 911 with original 502 191 miles...808 198 km
Old 06-21-2023, 07:45 AM
proporsche's Avatar
here some genius helped himself with a stretched chains...welded some extra on the arms to cover the space...oh ya the chain was rubbing on top a little..That was 911 imported from over the pond.....
Ivan
[IMG][/IMG]
Old 06-21-2023, 07:52 AM
Woooooooooooooow.
Brewster Green 1977 911S Outlaw
Hot 2.7|10.5:1|Single Plug|Knightrace Cams|Weber IDA40's|SSI's|MSD Ignition
Engine Built by Will Pyle
Instagram: indy.alex.g
Old 06-21-2023, 08:08 AM
gearhead
Seen that waaaaay too many times over the years.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 06-21-2023, 08:54 AM
Behind the Sun
Top Dollar
One of Kind
Unobtainable
They don't make them anymore.
You won't find another one this condition
Has all the paperwork
Blah Blah Blah. I feel sorry for your customer.
Old 06-21-2023, 09:30 AM
Original Owner
tsuter's Avatar
Its these peeps think they can R&R rocker shaft seals with the engine in the car...and then they give up and stuff the rocker shaft recesses with silicone.....
tsuter
78 911SC Turbo Targa
Thaaaats Right!!
Old 06-21-2023, 10:07 AM
I have added them with engine in situ. It can be done correctly.
Old 06-21-2023, 10:40 AM
theiceman's Avatar
for the record i replaced all my rocker shafts with the engine still in the car. I had the exhaust off to upgrade to SSI anyway . Upper back couple were finicky , bot other than that, not too bad.
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 06-21-2023, 11:19 AM
Still here
pmax's Avatar
Yeah, I hear you.
Wasn't that a well known pro shop as well ?
Old 06-21-2023, 11:32 AM
PCA Member since 1988
Likewise here. I did it a few months ago with the engine in the car, and it was a PITA to get those suckers back in with the RSR seals on them, but a couple thousand miles later, they aren't leaking, so I must have done something right.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 06-21-2023, 01:20 PM
1978 911 SC
Originally Posted by pmax View Post
Yeah, I hear you.
Yes it was... insert face palm here...hah
Old 06-21-2023, 01:41 PM
Wow...
I'll admit that I've rebuilt only two auto engines (one a 327 Chevy and the other my 2.7). Each was a very different animal. In both cases I did a ton of research and reading first to understand what to do (and more importantly what NOT to do). Lots of great info here and in many books related to proper sealing and assembly of 911 engines. There is no excuse for what is seen in those photos...
Old 06-21-2023, 07:48 PM
As a former mechanic, and engine builder, looking at this I despair; and how much I wonder was the over-all cost of this experience ???
"But instinct is something which transcends Knowledge
We have undoubtedly certain finer fibres that enable us to perceive truths when logical deduction or any other wilful effort of the brain is futile"
Nikola Tesla
Old 06-22-2023, 05:10 AM
Holy hell, when I saw the late model cams with the early big nut and washer with a bolt and spacer, I have to think that the guy never even bothered to look up the prices of the parts to do the job right. For about $30 he could have done it the right way.
Old 06-22-2023, 06:36 AM
