Random Oil Leak during Practice Rally
Howdy all,
During a run last night, I noticed a larger than normal oil leak under the right heat exchanger. Upon investigation it seemed to be starting somewhere around the top right passenger valve cover area. The oil pooled mostly on the engine tin and then dripped down.
No leak from oil filter. No obvious leak from valve cover itself, Seam mostly seemed dry.
I tightened the Cam oil lines down months ago during the engine rebuild And I used RSR seals on my rocker shafts.
I’m going to double check everything, clean up the oil and watch for the origin. Posting here for any extra ideas for what it may be.
Old 07-07-2023, 06:34 AM
proporsche's Avatar
try to lose the bolt on the cam line and check the oil fitting alu.seal
..here-black arrow
1985 911 with original 502 191 miles...808 198 km
Old 07-07-2023, 09:33 AM
Kind of Blue
MrBonus's Avatar
..here-black arrow
Yep, good chance your culprit is with the chain tensioner oil lines. I had a similar issue and simply tightening them wasn't enough. Had to replace that top middle line (which was a surprising PITA due to having to bend the new line to fit).
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel)
2024 Ford Bronco Raptor
Old 07-08-2023, 05:52 AM
