1973 targa top adjustment
hi all . im trying to adjust my targa. i think i got it pretty well adjusted. i just cant find any pics to look at. and see if mine is the way its supposed to be. i know the targa has flaws. the back window on both sides dont quite fit it the grooves of the side seals; both the targa side seals are the whol way out. heres some pics. please let me know how it lookse
Following
Sent from my iPhone using Tapatalk |
Looks pretty good.
I think that air is going to blast through this area. The rubber gasket should be visible to the edge of the frame and fill the gap that is shown.
78 SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8 HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS Last edited by snbush67; 09-04-2023 at 06:52 PM.. |
I have a small gap there on my '78 Targa. There's no "air blast" and no rain enters at speed.
-Tony Instagram: @Pablo_the_Porsche | @RuchlosRallye AchtungKraft #002 |
i sprayed water on top of both vent windows. not much gets inside. just a few drops. but both back tops of the windows arent going into the groooves of the side targa top seals.unless i use some force as i close the doors.
Looks very good, but do you have the front window frame seal installed? I can't see it, you are going to need one from carsincnj(dot)
Dan Pechtel The Porsche one will not work, the front edge of the roof should be as close to the frame as possible. The side windows are ok unless you have noise. The corners of your windshield trim need to be pushed out the seal is not seated and water will get in.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
I took a second look and I agree with you. Good eye.
78 SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8 HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
i did purchase to right front seal from dan the targa man
Do you have the Factory Targa manuals? I PMd you.
I have a small gap there on my ‘80 Targa and it’s not an “air blast”, but I do get air and attendant wind noise in through there, and a little bit of water in heavy rain.
'80 SC Targa Avondale, Chicago, IL |
