So just one point to circle back on this as I specialized in flat six exhaust for the last 25 years. The reason for poor vacuum signal was/is the header size. Back when Richard Parr owned PMO he called me and asked that I stop selling 1.625 headers to folks with engines smaller than 3.0 and it wasn’t once but multiple times. The PMOs had such a poor vacuum signal with larger primaries the cars ran terrible down low and would idle terribly.
Otherwise carry on looks like you’re doing a nice job. |
The very best must have book for tuning theory I've seen is this book written by Greg Banish
https://www.amazon.com/Engine-Management-Advanced-Greg-Banish/dp/1932494421 Must have for anyone wanting to learn the proper way to tune. His other book is also worth having: https://www.amazon.com/Designing-Tuning-High-Performance-Injection-Systems/dp/1932494901 Greg was my mentor when I designed and tuned my MAF system for the 84-89 3.2L. Greg is one of the most talented free-lance tuners in the world, often hired by FORD and GM labs for his services. He was instrumental in helping FORD with the eco-boost engine design. |
Here's a hint for AFR target during initial tuning, set your AFR target table to 12.8 across the board. That AFR is safe at WOT and will also work at PT and Idle, it's rich but it allows you to watch for just one single number on the AFR gauge. This means you don't need to think about the target AFR, your target is the same at idle, PT and WOT very easy for you to remember.
Then once the VE table is fixed up to hit your target you can then go into the AFR table and do the final desired settings. |
Feel free to PM me with your email as I have experience in tuning these engines I can give you decent idea of ignition needed at idle, PT and WOT as for fuel just target 12.8 across the board for now, that AFR should run just fine.
But using MAP based tune on ITBs may not work so well, do you have the option to use TPS? or a combo of TPS and MAP? The very best would be to build a air tight plenum on top of those ITBs then a horn off the plenum with a 3" MAF :) and use true MAF for metering air very accurately. Something like this can easily have MAF sensor adapted to it. https://www.fvd.net/us-en/FVD11096405/rsr-style-individual-throttle-body-kit-964-993-magnesium-for-mass-air-flow-sensor-street.html Here's example of itbs with MAF, not a 911 engine but to give you the basic idea https://myndasafn.bmwkraftur.is/d/46292-1/airbox+_Large_.jpg Quote:
Another hint: these engines need very little if any acceleration enrichment. Do not apply any accel enrichment initially, especially with ITBs even less is needed. The reason we need it is to replace the fuel that settles on the walls of the plenum but with ITBs you have no plenum! Greg's book covers this topic in detail.
OK, so looks like MAP/KPA is a no go, I'm not surprised when using ITBs.
TPS is your best bet with ITBs but you must map out the load rows in the tables to carefully match the various driving conditions. Idle, PT and WOT voltages. No point having a row in the table that you can't get to. For example if the max WOT voltage from the TPS is 4.5vdc then no point having 4.75 and 5.0 vdc rows. Hope that makes sense. Does the EFI have the ability to have idle dedicated tables? Like could you install a idle switch that the EFI reads? It would allow for things like decel fuel cut, where if the throttle blade goes back to idle stop and down hill coasting the EFI can then shut injectors completely off. Quote:
Really nice work you are doing on your car Dan, and very thorough documentation that will help other people following in your footsteps. http://forums.pelicanparts.com/support/smileys/clap.gif
Also some great pointers on things you should watch out for from people with a lot of experience building and tuning these cars and their engines. Not sure if you missed it but did you address the (too much) amount of Loctite on the cam boxes that Ian and Mike have pointed out? I'd listen to Ben on exhaust and header selection advice as well, not many people know as much about them as he does.... Quote:
Lukas |
Dan, Julian and Sal(hope I didn’t miss anyone),
Thanks to all of you for sharing tables and tips on tuning. I have so much to learn and everything helps! Dan, I have seen similar results when checking my TPS on the data log and I wonder if you would(me) would be best served with a bunch of tiny increments in the zero to maybe 5% and then larger jumps up the scale? My take is that for normal cruising, you aren’t really giving it much gas. Rutager |
Dan,
Sorry if I missed it, but your spark advance seems very high in some cells. Can you explain the reasoning and how it works? Good luck at the dyno. I called every dyno place I could find in the metro area of MN and couldn’t find anyone would could/would tune my car. Would have loved to have had a pro get there hands on mine. Looking forward to reading about your results. Thanks, Rutager |
See here: https://www.hpacademy.com/previous-webinars/229-engine-break-in-myths-dispelled/ I hate seeing people waste their time... |
Thanks, great explanation. I just ordered the book as well. Rutager |
How did you end up at 14° for your idle?
The twin plugged 964 pushes timing up to nearly 45 degrees at low load. Map courtesy of Steve Wong's 911 Chips site:
http://forums.pelicanparts.com/uploa...1721922890.jpg |
Damn Dan!
You know I’m going to be calling on you when I finally get my ‘74 body back from paint and place Al’s little gem in the back. Transmission rebuild started today. Took 6 weeks to get an original Porsche R&P from the dealer. Think it came over on a luxury liner, in the Captains Suite. The Dyno tuning is something I want to get done after it’s in and at a baseline. Thanks for the amazing write up. I’ve been quietly following your progress. Tony |
Dan,
That's impressive, well done! As a fellow 2.7 owner that has been following your journey, would you mind summarizing the changes you made to your engine? I plan on replicating a lot of your changes. Thanks, Kevin |
Hi Dan,
Impressive gain to have an extra 18% power just from (additional dyno) tuning! As an inexperienced noob, I'd love to learn here: - I thought your air fuel ratio was already fairly close to ideal (e.g. 12 or 12.5:1 at 100% throttle, leaner for cruising), as you had been tuning with a wide band already. What parameters did the tuner change, to get that much extra power? - Given that the power and torque built up more linearly previously, what is causing the drop in the mid 3000 RPM range, and could it be tuned out, without affecting the high RPM range? Cheers, Lukas |
Dan,
Thanks for the info, much appreciated! Can you comment on the reasoning behind your decision to upgrade the cylinders? Could you have used the JE 92mm pistons with your existing cylinders? Also, I'm guessing the extra deck height is what caused your compression ration to go from 9.5 to 9.8? Cheers, Kevin |
Hi Dan,
That certainly is a significant dip in VE between 3k and 4k. I'm wondering, that since its basically inefficient cylinder fill and slow to light-off, if increasing your ignition advance in that area might help. Similar to cruise state low VE timing. |
Ah, a good dyno tuner is hard to find. Tuning to MBT is the only way to properly tune. Sounds like you have the right guy!
Sounds like a great build! Congrats!
Can you explain the last dyno pic? Legend shows TQ as blue and HP as red, but on my screen it shows red and green lines? Maybe it is my laptop. Can you post just a final run HP/TQ with no previous data overlay? That plot looks like a big loss in the 3000-3650ish range? Maybe also post an AFR plot to go with the power curve. Cheers |
| All times are GMT -8. The time now is 12:12 PM. |
