915 trans
Does anyone know what size axles are needed for my situation? I have a 914 with a 964 3.8 L engine 915 transmission with a wave track course splines flipped ring and pinion. I have 108 mm course spline transmission flanges with 6 / 10 mm bolts. 108 mm 911 stub axels with 6/ 10 mm bolts thanks for any info. Slammin
Go to 914world.
Indeed; 914World.com is your place for all things 914 related.
'71 914-6 #0372 '17 Macan GTS |
gearhead
Iirc, you need to build a hybrid cv axle using the cv joints that match your flanges, mounted to the axle that’s the right length. You’ll definitely find the details on 914world.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
