Gas too old?
Finishing up an engine out clutch project which spiraled into a horrible case of "whileyourinthereitis"... Since I'm about done, I sent the injectors out to be refreshed by RC and then realized the gas in the tank is from August. Do I need to drain it and put fresh in? I don't want to mess up my newly cleaned injectors. FWIW I always use high quality fuel but still...
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
I don't know what it's like in the USA, but here in Germany, according to the petroleum companies, gasoline has a shelf life of at least half a year, regardless of whether it contains ethanol or not (5 or 10%). I assume it's the same in the US. so no problem.
Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL. Last edited by Schulisco; 12-18-2023 at 10:19 AM.. |
August will be completely fine
Sent from my Pixel 7 using Tapatalk |
Worst case, just change the fuel filter
Cheap insurance |
If it has been stored indoors, and not experienced wide temperature variations you should be fine. The biggest worry is water condensation if it is gasohol. Maybe top it off with fresh gas from a can, and drive it.
It should be fine.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Well crap...I just found a pic on my phone with the muffler off....FROM APRIL! I guess I'll be draining the tank. Not looking forward to that.
Don't panic! Even if the fuel is a bit older than 6 months - from my point of view there's still no need to drain it. Todays fuel detoriate above a year of storage. It hangs together how much fuel is in the tank, how's percentage of ethanol, works the tank ventilation, temperatures and even humidity. The only thing is the fuel begins to loose igniteability the longer its not consumed...so you can an octane booster for feel better...
any benefit to some sort of additive before I start it up? Other than octane booster. I put 92 in since that's Premium in Dallas.
On a side note. Am from Dallas too. Have a silver targa. Come do say hello if you find me
Silver 1987 Porsche Targa Carrera Build thread: 87 Porsche targa! projects tracker |
Comments are contrary to anything I’ve heard. RV aka ethanol free is good for 6 months and ethanol breaks down after a month. I also use seafoam once a year to clean up the fuel system.
No worries, it will be fine. An extreme example: My friend bought a running project car (66 Chev 6 cy) which then sat in his garage for 7 years before he unloaded it. He put a battery in, couple of pumps on gas and it started up with no issues. I never would have believed it possible had I not seen and heard it for myself.
1986 Targa Guards Red 2021 MT09 SP |
It's a 914 ...
Use the opportunity to put some Seafoam in the tank. Run it to empty-ish and change the filter.
Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL. |
PCA Member since 1988
I've experienced problems with carbs after sitting for a month with 10% ethanol. Fuel injection is a lot more tolerant of sitting because the system is sealed from the gas tank to the injectors. Still, I don't like to let cars sit becuase crap does happen to the fuel after enough time.
Go for a good long hard drive, get down to the fuel low light coming on, then refill with fresh gas. If you run into problems, put some Techron concentrate in it and continue driving. Otherwise, drive it regularly.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Strongly agree. 6 months is fine. Tons of us park our cars for 4 months over winter. Run some Sta-bil, Seaform or Liqui Moly fuel system cleaner, run the car down to empty, fill it up fresh.
1978 911 SC (3.2SS, EFI, 993SS cams + the trimmings) Dynamic Comp Ratio calc: https://dcr.questionable.services/ • Gearset & Ratio calc: https://ratio.questionable.services/ |
Targa_PB_78_SC
My 2 cents
BareRearedRookie |
Targa_PB_78_SC
Good idea to run the tank close to empty (leave a gallon in) fill it up add seafoam and rinse and repeat, once you are close to a gallon again, fill and add seafoam. Stabil or Driven injector defender, then you should be good for close to two years. I always try to cycle my gas through in 6 months though.
BareRearedRookie |
Buy a battery powered siphon, lots easier than draining. Pull some out and add non ethanol.
I also recommend to use fuel stabilizer on every fill up. Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL. Last edited by Schulisco; 12-21-2023 at 08:20 AM.. |
