shoooo32's Avatar
I put a rennshifter in my SC when I bought it eight years ago, but I'm going to clean up the stock shifter and try it again. I agree - the short shifters are a little notchy and I didn't give the stock shifter a fair shake.
If you rev match (heel toe) you can 2-1 shift at 25mph without issue. If I'm autocrossing or climbing steep grades on a rally, I'd rather drop to 1st than lug the engine in 2nd. It's hard on the synchro but I built it once (actually twice) and I'll build it again when it needs it.
-Tony
Instagram: @Pablo_the_Porsche | @RuchlosRallye
AchtungKraft #002
Old 01-15-2024, 01:05 PM
Still here
pmax's Avatar
Originally Posted by gduke2010 View Post
Yes I do have a short shifter.
Timely.
Just test drove after making the long John shifter mod.
It's the ticket to finger tip shifting. Nice !
Old 01-15-2024, 04:19 PM
gduke2010
gduke2010's Avatar
Originally Posted by proporsche View Post
well? did you??
Ivan
Yes, sooner than the 500 mi. break in though.
Old 01-15-2024, 04:22 PM
gduke2010
gduke2010's Avatar
Originally Posted by pmax View Post
Timely.
Would like to hear about the mod.
Old 01-15-2024, 04:27 PM
Still here
pmax's Avatar
Here's the John Walker long shifter thread from 2005 !
https://forums.pelicanparts.com/porsche-911-technical-forum/240038-amazing-long-shifter.html
Yeah, the long shifter seems nicely tuned to the 915's shifting cadence. I even got it to shift from reverse to 1st without a deliberate pause.
The extension is from TimmyT, a very well designed and made product, reversible to boot.
https://forums.pelicanparts.com/porsche-911-technical-forum/1006707-shifter-rod-extensions.html#post10166006
A nice post from 911pcars Sherwood RIP explaining the "mechanics" ... https://forums.pelicanparts.com/porsche-911-technical-forum/486577-shift-lever-extension-ala-john-walker.html#post5030983. He sold extensions as well. https://forums.pelicanparts.com/porsche-911-technical-forum/623159-yet-another-shifter-thing.html
Old 01-16-2024, 12:25 AM
gduke2010
gduke2010's Avatar
So the short shifter is the length of the shifter. I thought the short shifter or something internal.
Old 01-16-2024, 06:14 AM
PCA Member since 1988
The Porsche short shifter internals are different. The lever sits at the same height, but the throw is shorter and slightly stiffer because of the reduced leverage. I can't say whether this is true for other short shifters, but I expect it is.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 01-16-2024, 11:23 PM
gduke2010
gduke2010's Avatar
The only reason I knew I had a short shifter, was looking at the receipts. When I bought the car I seen one had been installed.
Old 01-17-2024, 10:28 AM
