Stophos's Avatar
Tach signal wire?
I have no continuity on my tach signal wire from the engine bay to the dash. Can anyone confirm if the black/violet wire in an SC goes directly to the tach without any plugs along the way or if there is a plug where is it located?
Thanks - Chris
Looking for:
1969 911T - Engine - 6196603 & Gearbox - 7196742
1969 911S - 901/13 Gearbox - 7195559
Old 08-12-2023, 11:43 AM
I'm searching for this too I believe 1980 and up SCs have the wire going to a TD box under the dash
Then to the tach
Maybe someone can chime in more info
Old 02-04-2024, 02:38 PM
PCA Member since 1988
There also is a 14-pin connector towards the front of the relay board and the black/purple goes through that connector to the chassis wiring harness. Check both sides.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 02-04-2024, 03:26 PM
T14/12………
Chris,
The tachometer wire (black/violet) from CDI to tachometer goes to 14-pin connector @ pin #12 for all SC’s. Do the continuity test for both sides of the 14-pin connector (male & female sides).
Tony
Old 02-04-2024, 05:18 PM
