Troubleshooting - What is this plug 911 3.2 G50
Hi all,
I added an inline fuse to the blower motor in the frunk and noticed a plug that was not connected to anything. Does anyone know what its for? Can't for the life of me figure it out.
IMG-20240105-144745
quick image upload
Old 01-17-2024, 09:42 PM
proporsche's Avatar
it is for your windshield washer motor ,should be right in front of the battery
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 01-18-2024, 02:40 AM
Ivan
Thanks Ivan. That was my first thought, but my washer motor works without that plug being plugged in though. Made me think it's forndoemthing else.
Old 01-18-2024, 12:05 PM
proporsche's Avatar
let me see the connection on your washer pump. This connector shows for the washer P.on diagram
Ivan
Old 01-19-2024, 01:39 AM
Check operation for right side High beams or Fog lamps… perhaps the other connector is buried behind jack.
I don’t have diagram, but think green/white for fog lamp, brown and black was on washer pump last time I replaced mine.
Old 01-19-2024, 07:30 AM
Thanks for the replies.
My fog lights are not working. They haven't since I bought the car. Just haven't got around to fixing them.
Possibly the fuse blew for washer pump and they've connected washer pump to fog lights connector instead of changing fuse?
Will have to have a better look.
Old 01-19-2024, 01:27 PM
proporsche's Avatar
fog light wires are white and yellow-and brown to each light...
Ivan
Old 01-19-2024, 04:39 PM
That's fond- just deglaze
Hi Wangan - Thanks for posting- great timing!!! I was looking at my unhooked plug earlier in the week with dread and wondering the following:
1) What does this connection run?
2) Why do my Headlamp Washers not work?
Just to be safe, I grabbed a 12V battery pack, hooked it up to the male ends, and was able to prime my washer lines!
I have no doubt I inadvertently unhooked the connection during battery removal. Regardless, my Headlamp washers are back after having seen this post!
Missed Approach
Petra- 1986 Coupe
Old 01-19-2024, 05:41 PM
Thanks everyone. Still no luck.
I've taken some more photos to see if anyone can help identify. Appears my washer bottle is hooked up and working. My fog lights are not working, but I cannot see any lose wiring anywhere for them in the front base of the frunk area. Any ideas?
I see one plug opposite to the washer bottle, which may be fog lights?
There is nothing long enough or close enough to connect to the loose plug as far as I can see.
Old 02-01-2024, 07:08 PM
The connection you're showing on the RH side should be for your oil cooler temp sensor and ground. Does your oil temp gauge work?
For your fogs, you can pull the relay from the fuse panel, turn them on, and check for power at the panel. If you have power there, plug the relay back in and check for power at your light. If you don't have power there, suspect bad relay or wiring.
Old 02-02-2024, 09:05 AM
I'll give that a go. Thanks.
Strange, but my oil temp gauge is working, so not sure why the plugs there.
Old 02-02-2024, 10:17 AM
Hi Wangan- Just to confirm- do you have Headlamp Washers? I checked my connection, and my wire colors are Yellow and Brown(as in your photos) but with a Black, not White connector body. Your white female plug is in the exact location of my black female plug. The male end (from the headlamp washer pump) had gotten buried under the condenser fan housing. Hoping this provides further insight.
Missed Approach
Petra- 1986 Coupe
Old 02-02-2024, 12:30 PM
I do not have headlight washers. Is it probable that the plug is there on all 3.2s and plugged into headlight washers for those that have the option?
I do not see any male plugs there at all.
Old 02-02-2024, 05:17 PM
Checked again. Cannot see any any plugs anywhere in the front area.
Old 02-04-2024, 07:40 PM
