Carrera wheel spacers
Having a bit of trouble finding the answer searching.
What is the consensus on biggest spacers/adapters I can add to the stock 6” and 7” Fuchs on my Carrera to fill the fenders/quarters without rubbing? Thanks gents. |
Rescuer of old cars
I ran 25mm spacers on the rear, none on the front. Depending on how low you are, you could go up to 25mm on the front, and maybe 35mm on the rear, but watch for rubbing.
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
Anybody else have input, pictures? Thanks |
Mine has 30 mm on the rear (16inch fuchs) and no rubbing, none in front.
I've run 21 and 23mm spacers on the back wheels of my last two 3.2 Carreras. Looks good and plenty of clearance. Haven't bothered to do anything with the fronts.
Run sticky tires and that's all you need to do I think. |
I run 24 mm spacers in the back and 6 mm in the front.
Juergen
'86 Carrera Cabriolet Grand Prix White '09 VW Beetle Convertible ‘24 Audi Q8 etron |
On a G50 Carrera with 6/7 and 205/225 I ran 15mm all the way around (the car had longer studs). It was low and didn't rub.
My car is lower than Euro spec thanks to the PO (hmmm) and I found there is a 10mm spacer in the rear. I run stock tires and just at the point where a finger doesn't fit in the space. I don't rub but it's soooo close. My studs are original too and they are just at the point where I feel ok but any more and nervous about not changing to longer ones.
I run 21 mm in the rear. Nothing in front. I was thinking of running 5mm up there
ken 87 targa |
28 mm spacers on 7 X 16 rears with 225/50 tires , stock suspension.
https://www.pelicanparts.com/cgi-bin/ksearch/pel_search_2016.cgi?command=DWsearch&description=HR-5695716+++ No rubbing whatever
1958 356A - Sold to a rust collector 1978 924 - sold to a sewing machine repairman 1984 944 - meticulously maintained but everything except the drivetrain self-destroyed. Used in trade for my wife's MB 1988 Carrera 3.2 Targa - purchased in 1992 and still thriving. Boy, do I love this car |
I also run the same spacers on my 86 Carrera, the fit and look are spot on!
Ron 73.5 T 74 R90/6 (Tupelo Honey) 86 Carrera (Plan B) 1987 BMW K100RS Motorsport |
This thread would be great if it had part numbers/brands descriptions of stud lengths and more.
I think a lot of people want to space out the rears especially, but there's precious little recommendations / reviews on the topic. |
Coastr,
With the bolt on spacers, I probably recommend the H&R brand for quality in whatever width you fancy. The Trak+ versions have their own wheel studs to fasten the wheels to and use the factory studs to hold the spacer in place if that makes sense. So simple and quick fitment as they have worked it all out for you. However for the rear of my current car, I wanted a "factory parts" look so opted for genuine Porsche 21mm spacers that came with early 944's (477 501 701) and used 72mm wheel studs (993 341 671 03) Porsche also did a next size up 28mm spacer (930 341 611 00) but I think is a touch too wide for this application. Last edited by Peter M; 06-08-2019 at 09:53 PM.. |
Dial 911
![]() Quote:
Over the years we have owned two of them...They’re a ‘pretty’ 911 ay!!
Cheers! “Simplicity is the ultimate sophistication.” Leonardo Da Vinci |
Here's my '86 with 28mm in the back and nothing in the front. Stock 16/6-7s. The ride height is set to Euro specs.
H&R TRAK+ 28mm Wheel Spacer Pair - DRM Style, Bolt Pattern 5x130mm, Center Bore 71.6mm, Thread Type 14x1.5 Sold by our host. Here's a link to a thread with more photos: https://forums.pelicanparts.com/porsche-911-technical-forum/1134193-wheel-spacers-3-2-carrera.html ![]() ![]()
_____________________________________ 2017 Targa 4S | 2016 Cayman GT4 Clubsport 1997 Carrera S | 1986 Carrera 2016 Cayman GT4 [sold] | 2015 Macan Turbo (sold) | 2006 Cayman S [sold] |
