Sill Trim
Is there an accepted way to fix the aluminium trim that runs under the door without putting self tappers through the sill?
1965 911 rhd |
PCA Member since 1988
I used screws instead of rivets. I figure I'll have to take them off again several more times...
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Thread Tools | |
Rate This Thread | |
