3.2 just died after a ride.
After a good ride today in the Outback I pulled up to my house and car just died!! Has gas , turns over just fine. It’s not getting gas because when I spray some carb cleaner in the intake it starts for a few seconds only. So far I replaced the DmE relay, the fuel pump relay and fuel pump fuse. Still no start. Expensive fuel pump was replaced 5 years ago with very few miles on it. All sensors replaced 6000 miles ago with top end. Car ran great on ride today then just stopped!!! Ideas please. Could a dirty fuel filter cause gas to just stop ??without warning ? Thank you.
Old 05-03-2024, 07:36 PM
Did you fill up the tank on your way home? Are all the relays you replaced new or old ones you had for spares? Newish fuel pump could still fail or maybe a wire on the pump come loose. Can you bypass the FP relay and force the pump to run?
I have a 3.0 so different but just throwing stuff out there. Good luck you will figure it out.
Old 05-03-2024, 07:51 PM
The dme is new, so is the fuel pump relay and fuel pump fuse. So next I must move on to replace the fuel filter and then check the fuel pump. But car ran fine today would either of those just stop working? Just like that??
Old 05-03-2024, 08:36 PM
My car was low on gas but still showed some on the gauge. If I did run out is there a way to prime the fuel pump after adding gas?
Old 05-03-2024, 08:40 PM
proporsche's Avatar
do you hear the pump running with this test ?
5-6 fuse with jumper-direction from the windshield...
1985 911 with original 501 587 miles...807 226 km
Old 05-03-2024, 10:29 PM
Thanks , will try this tomorrow.
Old 05-04-2024, 02:25 AM
If your Carrera is stock there is no fuel pump relay but only one DME relay. So I wonder what exactly you replaced.
DME relay is under driver seat near the ECU. You may try to jump the 3 terminals on the DME relay socket. This should force the FP to run and you should hear it. Then you can try to crank and see if the engine starts.
Old 05-04-2024, 02:58 AM
You are wrong sir. The red relay in my 85 fuse box is the fuel pump relay. It is right in my owners manual diagram. It is also located in the fuse box lid that reads “fuel pump relay”. I went to local parts store yesterday and it came up as fuel pump relay. I replaced both the relay and the DME relay. Also, if you go to pelican parts, they sell it also.
Old 05-04-2024, 06:35 AM
Here is the story, sad but true, I did the test above , there is no fuel pump sound at all. Weird. I bought the best fuel pump a few years ago. I guess that’s next. New dme! Fuel pump relay and fuse. Motor just stopped after a great ride! Bummed!
Old 05-04-2024, 09:09 AM
proporsche's Avatar
if you have jumped the fuses and no power to the pump ..it is the pump..sorry..
Just double check the bottom wire on fuse 6 if it not loose...
Ivan
Nick, Carrera pump does not have red relay for the pump only DME relay under the seat and the fuse no.6
The cover could say that but it is most likely from the 930 cover.....it is misleading
yours should have this number 911 612 161 06
Old 05-04-2024, 09:49 AM
Thank you Ivan I replaced those relays anyway, cheap. Also ordered a new fuel filter, good to have anyway. I’m not in great health and I really don’t want to crawl under car to change out pump but!!! I will. Weird that it just died!!! Thanks for your great advice!! Was a wonderful ride yesterday until it stopped!!!
Old 05-04-2024, 09:57 AM
Btw, my fixed are clean as a whistle! All tight. I’ll try another fuse just to be sure.
Old 05-04-2024, 10:00 AM
proporsche's Avatar
Double check the wire bottom...also you do not have any kill switch tied to the fuel pump..correct?
Old 05-04-2024, 10:02 AM
Still here
pmax's Avatar
The DME relay is the fuel pump relay.
What does it say on the cover of the owners manual ?
Old 05-04-2024, 11:00 AM
I'm glad someone is confirming this. Really thought I had too much beer. ;-)
Old 05-04-2024, 01:51 PM
Manual says
1985 911 Carrera. Here is a page from the manual.
Old 05-04-2024, 02:03 PM
proporsche's Avatar
yup, see post no .10;-))))
Ivan
Old 05-04-2024, 02:06 PM
More
More
Old 05-04-2024, 02:10 PM
I guess every once in a while Porsche got the info wrong!!
Old 05-04-2024, 02:11 PM
PCA Member since 1988
Nick, if you haven't already, remove, clean and reconnect the connections to the fuel pump. I didn't see if you had done that. Then make sure you have voltage at those connections. Then with power to the pump, whack it with a block of wood or small hammer or such.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 05-04-2024, 03:00 PM
