Help needs with Identifying flywheel
Trying to replace my flywheel since some of the teeth are crunchy-
Porsche 914 six conversion
Engine end a1976 euro Carrara 3.0.Essentially a 2.7, 2.4 crank
901 transmission
6 bolt flywheel. Part stamped on it 901–102–205 – OR.
Clutch surface radius measures 225 mm
Note the center hub that holds the needle bearing
In talking to Patrick Motorsports , it seems the newer part number is now 901–102–026–02
- however it looks like it’s 215mm radius.
- missing the center metal hub
On the web, Sierra Madre has a similar looking fly wheel with part number 90110202601
- no center hub either.
Not sure where to go from here, as I can’t seem to find fly wheel with the correct tub.
Appreciate any help
one.
Old 05-07-2024, 01:31 PM
The center item is a pilot bearing, bought separately.
206 637 4071
Old 05-07-2024, 03:07 PM
It's a 914 ...
stownsen914's Avatar
Do you know what clutch was on it? Porsche didn’t make a 225 mm early (2.0L) style flywheel to my knowledge. Unless someone had a 2.0L unit machined to accept a different pressure plate?
Old 05-08-2024, 05:07 AM
