rear windshield with no heater lines?
Hi all
I was just wondering if anyone knows of a source of green-tinted rear glass for a 911 coupe, ideally without the heater lines? I have found suppliers with the front windshield, but not the rear for some reason. Alternatively, has anyone tried to remove the heater lines? Thanks Tom |
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind. |
(man/dude)
They are certainly available. If you put a WTB ad in the classifieds you might score a used one. I think the heating wires are between the layers of glass.
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
Hmm thanks Jonny. I was hoping to physically remove the heater lines so they are no longer visible, but clearly if they're sandwiched that won't be possible.
I believe they are glued to the inside of the glass. On my 87 when I was getting it tinted they said some of the lines were coming off and that I would have missing spots for the heater.
You might double check the old glass, I think you could use a razor blade to strip the lines. CTopher |
(man/dude)
I looked through the auction listing for Project Heavy Metal and couldn't find a better picture but this does give an idea:
Believe me, I'm fully onboard with you. We've not met, but I certainly lurked on your project threads, and I'm also in Canada (Quebec). Is your rear glass green tinted or clear? One vendor has clear glass without the lines for early cars, but the rest of my glass is green and I'm concerned that it might look odd to mix them.
Titanium User
912 part number I believe - putting one in my st build
Buy some Titanium Lug Nuts! http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1032311-fs-titanium-lug-nuts-studs-v2-0-a.html ig: @ti_porsche_products |
Look for short wheel base ( swb )rear window,
Are availble but difficult to ship. I got mine from sportwagen Eckert porsche. Last edited by 959swede; 05-16-2024 at 07:39 AM.. |
I believe Sierra Madre has them for under $600. but that was years ago
(man/dude)
I figured I'd dig a little deeper. 2 mins with the PET and.....
90154510130 Google turns up several sources for new ones at reasonable prices.
(man/dude)
Thanks, all for the input. I just have to figure out what to do, and unfortunately budget comes into it as well....
