Re-keying my door lock
Pelican board.....
I am trying to gather the parts for a small project that involves the 79SC. There is a long story involved, but I am trying to get to some of the 'deferred' projects and maintenance on this machine - involving the door locks, door striker, interior door bits and so-forth. In wayne's book, he has a very good outline on how to re-key the lock cylinder on the doors to match the ignition key. However, it does not say where to get the bits that would be put into the cylinder. Also, a detailed search of the site has not turned up a "kit" of any sort that I could use to put the lock pins in to match the 6 points on the key. Can anyone advise where additional lock pins can be purchased? Or ... do I reuse the pins and reorient them to match the ignition key?
'The forever project car - 1979 911SC targa - getting it running right was a task, read about it here: http://forums.pelicanparts.com/911-engine-rebuilding-forum/722362-dads-911sc-i-am-finishing-rebuild-long.html Other cars: 1993 Corvette LT-4/ZF6, polo green. 22 Ranger 4x4 with a couple cool things. |
http://forums.pelicanparts.com/porsche-911-technical-forum/384665-source-rekeying-kit-porsche.html I have the ASP kit. For your car it is the same, kit ASP A-26-101. Has all the pins, springs and other parts to do the job of rekeying the doors, glove box etc. Use your ignition key. You will find the information on this PDF: http://www.carlocks.com/2008ASPCatalog.pdf In past years you could order from Carlocks.com online. Not the case anymore. However you may want to call them to see if they can sell you the kit. The had a change in management or ownership, but it is not easy to source the ASP kits. Here is the link: Auto-Security Products Also check eBay as I have seen the wafers, pins and springs for small versions of the kit. Best luck, please share your results with us.
Dan |
I never did have any luck finding the parts and just brought the cylinders to my local locksmith. for about $20 each they were rekeyed.
I just bought a kit off eBay, I'll let you know how it works
Ächtung Kraft Founder - Custom Porsche Parts and Leather http://achtungkraft.com - Bryan Rasch - bryan@achtungkraft.com INSTAGRAM // @AchtungKraft // @BrightonRennsport 1972 911 ROW Steel Wide body Outlaw w/'86 turbo drivetrain 1976 911S + 2006 911 4S + 2009 Cayenne GTS + 1988 944 |
Thanks fellas: I have done a little digging on the inter-web, and have searched ebay for the correct lock set. I have a locksmith that I have worked with in the past that I may be contacting once I pull the door handle. Either way I choose to do this, I will let the board know.
I buy them at key innovations.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind. |
