911SC '82
I'd like to install an MSD 6AL box to replace the Bosch CDI, but i'd like to keep if possible the black plastic connector and buy or DIY build one
I found this thread but the PDF is lost... https://forums.pelicanparts.com/porsche-911-technical-forum/455592-bosch-cdi-msd-answers-here-2.html I wonder if anyone sells something to easily adapt the MSD to CDI I read somewhere there is a user Timmy2 that creates those harnesses? or are there other places to find the wiring and parts to buy etc... Last edited by francesconyc; 05-29-2024 at 08:08 AM.. |
Found this old Pelican Forum thread you might find interesting; http://forums.pelicanparts.com/porsche-911-technical-forum/676385-msd-ignition-exposed.html
Dave |
911SC '82
Are you looking for the black 3 or 6-pin CDI connectors? If so, I found some at Kroon wire harness dot com
911SC '82
Slow old car
I believe what you're after is:
6pcs: https://www.mouser.com/ProductDetail/TE-Connectivity/42460-1-Loose-Piece?qs=rrS6PyfT74cd0dWE5XKDNw%3D%3D&countryCode=US¤cyCode=USD 1pc: https://www.mouser.com/ProductDetail/TE-Connectivity-AMP/180906?qs=r95CiIlKlrmLYeSVEs89SQ%3D%3D&countryCode=US¤cyCode=USD
Mike 1980 911 SC 3.1 Coupe // 1986 VW Vanagon Syncro EJ22 // 2015 Macan Turbo // 2017 i3 REX |
Yes, your 911SC uses a 6 pin CDI (6 wires). When using an MSD, a seventh wire is needed for a direct connection to 12V (red wire) at the starter motor.
Dave |
911SC '82
911SC '82
You are better off running a 12 gauge wire down to the starter to connect to the big black cable from the battery. That MSD B+ wire is high current.
Dan 1975 911 Carrera "CIS to ITB EFI conversion" thread Updated (2) Table of Contents pg17 post 339 |
This is the "adaptor" harness I made to install MSD AL-6 in my Son's
78 SC ![]() ![]() ![]()
'74 911 3.2 |
Timmy2 (Dennis) rewired my harness to convert my ‘71 from CDI to MSD Streetfire. Great work, excellent communication, reasonable price. I highly recommend him.
DHO |
+++ what doswald said. I have the Timmy2 connector for MSD in my '70 with 3.0. Just plug and play. Super easy. No wiring diagrams needed. Quality work. Give him a call. He's a good guy.
gary 70T coupe forever almost done 88 Carrera Targa diamond blue |
911SC '82
can i contact Timmy2 here with a DM?
911SC '82
yesterday i studies and labeled the new unit and it seems I have. A LOT of cables that will stay unused...
Why not rebuild your good old robust German Bosch unit instead of the MSD?
Yes, you can contact timmy2 (Dennis) here via pm.
dho |
