What is this tube near the oil pressure switch?
Anyone know what this tube is? There is nothing connected to it. It is a hollow tube with a rubber sleeve on the bottom. Thanks!
Old 06-02-2024, 12:10 PM
Never seen that before.
Old 06-02-2024, 12:21 PM
Here is a picture from above to see where the small end of the tube comes out.
Old 06-02-2024, 12:26 PM
Still here
pmax's Avatar
Probably for emissions control.
What engine is that ?
Old 06-02-2024, 12:27 PM
Oil drip diverter from the airbox. The protruding tube connects to the bottom of the airbox with a length of hose. Connected, the oil drips on the heat exchanger, as is, it drips on the engine. Brilliant idea.
206 637 4071
Old 06-02-2024, 01:04 PM
Maybe a catch can
HarryD's Avatar
^^^This.
Part number 911 108 021 02. Item 7/1 as shown in the PET.
Red line shows connection to CIS Air Box.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 06-02-2024, 02:18 PM
Holy cow you guys are fast. Thank you!!
The engine is a 1970 911T 2.2L sportomatic
Old 06-02-2024, 02:33 PM
HarryD's Avatar
The drain connection is on the bottom of your air cleaner.
Harry
2020 MB E350 4Matic
Old 06-02-2024, 02:55 PM
PCA Member since 1988
I took that off of mine. I never get oil on the floor of my airbox.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 06-02-2024, 03:44 PM
