Have u tried removing plug connectors or cap wire one at a time, the old rule was if the noise goes away it’s a rod, if the noise doubles, it’s a wrist pin, if it stays the same it’s piston slap. No hard truth to this, but something to try. Doesn’t sound terminal to me.
Old 06-23-2024, 12:56 PM
Registered Ass-hat
Mehoff's Avatar
Originally Posted by stubble88 View Post
Yeah. Sorry.
Car was a dedicated race car
Lots of motor work done by AASE in 2018
New clutch (stock)
New lightweight flywheel
Had straight pipes now has Dansk 2/2
New oil and filter
New fuel lines
Simple race harness replaced with good used one.
DME harness not changed.
911 chips custom. (This ill seek more info on)
Headers with Dansk. No cat
2018 AASE 3.2 build in a dedicated race car was almost certainly built to run 110. Don’t think that’s your issue, but it will become one if using pump gas.
Show a pic of the car and we can tell you if it was a SP911
Old 06-24-2024, 10:43 AM
had a lengthy conversation with Steve Wong from 911 chips. so this car has 95mm 9.5:1 Cp with pins, rings and clips. so more than likely this noise is from those cold race pistons doing some slapping before its super warm. Also tuned for 100 octane.
I'll need a new chip so I can run pump gas.
1975 911 3.4 outlaw/hotrod? lsd
1988 535i
1987 535is
1973 bronco ranger
Old 06-24-2024, 11:37 AM
SCR spec Carrera 3.2 race class
1988 535i
1987 535is
1973 bronco ranger
Old 06-24-2024, 05:27 PM
Update
-Valves adjusted
-New 911 chip with pump gas tune
-Timing chain tensioners checked. Looked new in there. Chain was tight
-new plugs
At first start up I heard nothing. But then it crept on and was still there.
Stethoscope (amazing) used. Everything sounded great and even. But this knocking noise was most noticeable on the fan house. Honestly. I could not hear the knocking until I touched the fan housing. Could it be the alternator? I’m going to let it cool and take the belt off and see.
1988 535i
1987 535is
1973 bronco ranger
Old 06-29-2024, 02:55 PM
gumby's Avatar
pop the belt off and see if the noise goes away (bad alt bearing) but dont run it to long, the motor will overheat!
Ron
73.5 T
74 R90/6 (Tupelo Honey)
86 Carrera (Plan B)
1987 BMW K100RS Motorsport
Old 06-29-2024, 03:11 PM
Not the alternator.
Seems to get louder as motor warms up. Not really there on initial cold start.
Seems to smooth out or is not present with revs
1988 535i
1987 535is
1973 bronco ranger
Old 06-30-2024, 10:19 AM
proporsche's Avatar
i still think as i have mentioned at post 7..The wrist pin when the engine gets war-hot.Did you locate which cylinder,yet?
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 06-30-2024, 10:33 AM
Ivan
Ive stethoscoped a couple times. It all sounds the same on every cylinder. Fan housing amplifies this knocking sound. Bottom of engine seems quiet.
1988 535i
1987 535is
1973 bronco ranger
Old 06-30-2024, 10:40 AM
Cold start. Sounds normal. But idle is a bit higher when cooler.
https://youtube.com/shorts/xoCcPnAEDok?si=KRrkkt-5kqOdrV36
Warm. Knocking sound shows up. Idle lower when warm.
https://youtube.com/shorts/m-xKjY6AADo?si=Sk4BD-UZcyNchIK2
1988 535i
1987 535is
1973 bronco ranger
Old 06-30-2024, 11:01 AM
proporsche's Avatar
i know you cannot hear it on the 1st video but i can in the distance.On 2nd it actualy sound not as one but 2 noises ..
I do not know the history of the engine but i have heard this sounds before.
One of my friends in LA very good 911 mechanic was chasing this problem ended up taking the engine (after rebuild),apart. Heating the pistons and only after this he found the wrist pin loose in one of the pistons.Mind you the measurements cold all was perfect..So when cold no noise only after warm engine..
Ivan
maybe some other engine re-builders here will chip in another idea
Old 06-30-2024, 11:26 AM
Pulled plug cables one by one. No change. Hardly even noticed it running worse at all.
1988 535i
1987 535is
1973 bronco ranger
Old 06-30-2024, 12:46 PM
Sounds like a lazy tensioner to me
Listen with a long screwdriver to both chain cases and try to figure which side
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car
77 BMW R100S
99 Ducati 996S
04 BMW R1150R
Old 06-30-2024, 02:15 PM
I think your right
I did another stethoscope and this time I could definitely point to the right chain cover as the loudest and most clarity of that sound. Left side was not as loud.
I mean it does kinda sound like metal hitting plastic. There was a bit of black oil soot on the bottom when I took the chain cover off and inspected. Sounds goes away with revs maybe because chain has more tension?
1988 535i
1987 535is
1973 bronco ranger
Old 07-01-2024, 06:04 PM
I think your right
1988 535i
1987 535is
1973 bronco ranger
Old 07-01-2024, 06:19 PM
Maybe another chip with a different tune, right? Something with a little less advance*than 45 degrees.
Dave
Old 07-01-2024, 08:16 PM
I got a new chip tuned for pump gas yes. Made no difference. But still needed
35 degrees down to 28
1988 535i
1987 535is
1973 bronco ranger
Old 07-01-2024, 08:18 PM
Steve W's Avatar
Chad, ignore mysocal911, he doesn't know anything about what he's babbling about - he's just a bitter old man.
Dan J, aka Dan Jacobs of Dan Jacobs Garage is one of the top tier Porsche shops on the East Coast, the nation for that matter, and a long time veteran of air cooled cars. When he gives you advice you can take it as solid gold.
Old 07-01-2024, 10:19 PM
proporsche's Avatar
are you able to push down the right tensioner??
Ivan
Old 07-02-2024, 04:02 AM
As the engine speed climbs so will the oil pressure, so I guess there is a possibility that the tensioner is not holding the right oil pressure on idle, allowing the chain to rattle, but as the oil pressure rises, it takes up the slack in the chain and holds, until the revs come back down again ?
I think your right
"But instinct is something which transcends Knowledge
We have undoubtedly certain finer fibres that enable us to perceive truths when logical deduction or any other wilful effort of the brain is futile"
Nikola Tesla
Old 07-02-2024, 04:17 AM
