Too much oil in my 1976 targa
I had a leak of oil and filled too much oil . About 3-4 liters more . After I started the engine it worked fine for a minute than it back fired and smoked a lot. The engine turned off - i took the extra oil out but still a lot of smoke . I dont want to make a mistake - what is the next procedure i need to make now?
Old 08-24-2024, 08:14 AM
pull the plugs and clean them
Old 08-24-2024, 04:22 PM
Go out at midnight and burn the oil out of the exhaust system. It goes through the engine and coats the inside of the exchangers and muffler. Might want to stay out of your neighborhood.
206 637 4071
Old 08-24-2024, 07:05 PM
Still here
pmax's Avatar
Check the oil level with engine warmed up and running, on "level ground". Don't rely on the gauge.
Old 08-24-2024, 08:44 PM
PCA Member since 1988
What John said. Go somewhere people don't know you and burn it out.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 08-25-2024, 01:32 AM
lol NIMBY repair
Old 08-25-2024, 05:24 AM
RSN RSN is offline
Make sure you know exact how much is in there now, and then go somewhere to burn all excess out like said before
Old 08-30-2024, 07:15 AM
wrxnofx's Avatar
Why would that matter at all? Drive the car until the oil is up to temp then remove/burn off until the oil is at the halfway mark on the dipstick.
1987 911 Carrera coupe - Guards Red
2010 997.2 C4S 6-Speed
2005 Mini Cooper Convertible (R52) - Wife's car
1977 VW Bay Window Camper Bus
Old 08-30-2024, 10:15 AM
