Engine dies when braking hard
I recently rebuilt the rear brakes on my '86 Carrera and while bedding them in per PMB's advice I encountered a problem. Twice when braking hard from 80mph to 10mph, the engine suddenly died and then restarted after downshifting to second gear and releasing the clutch, like it was roll starting. Every other time (8X60-10mph, 4x80-10mph) the engine ran normally. Any ideas why the engine died in only those two instances?
TIA,
Gordon Watkins
Old 09-07-2024, 07:31 AM
PCA Member since 1988
Is the fuel level in your tank low? The pump could have sucked some air.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 09-07-2024, 06:55 PM
I’m not entirely clear on what you were doing - were you in gear the whole time, or did you put it in neutral?
'80 SC Targa
Avondale, Chicago, IL
Old 09-08-2024, 11:38 AM
Just spitting this out, but any chance you have a vacuum leak in your braking servo system and the hard braking allowed unmetered air into your engine causing a lean condition?
Rutager West
Old 09-08-2024, 01:23 PM
Behind the Sun
Did you press the clutch when pressing brake pedal at the same time?
2 foot in if you know what I mean???
Old 09-09-2024, 07:30 AM
I been trying to figure why my brakes don't work well after my engine rebuilt, vacuum leaks came to my mind right away...
I make spelling mistakes and my written English is difficult to understand.
Old 09-09-2024, 12:29 PM
I had 3/4 of a tank.
In 5th gear then hard brake from 80mph to 10mph with clutch in. I did this several times in a row. It didn't die every time but twice it did and then re-startted when the clutch was released after shifting to 2nd gear. This is the break-in procedure for new pads recommended by PMB Performance, where I purchased the pads.
Yes, when I reached 80mph, hard brake with the clutch in. Engine died then re-started when I shifted to 2nd and release clutch pedal.
Thanks for the responses.
Gordon
Old 09-11-2024, 12:48 PM
My guess (uneducated as usual) is a vacuum leak at the brake booster.
Scott Wilburn
1988 911 Carrera 3.4 L
1998 M3
1984 308 QV
Old 09-11-2024, 05:57 PM
