VR1 dino is a well-proven oil for use in these cars. there's always that.
Which is why I still run it. Sent from my iPhone using Tapatalk
1986 Porsche 911 Carrera 3.2 |
I just bought a 6 quart case for $39 on Amazon.
TBD Prior: '84 911 3.2 Carrera, '83 911SC Targa IG: @heuersandcarreras "I want to use it. That's what 911s are for." - Richard Hammond |
My understanding from reading all of the many and extensive oil threads both here, and on many other boards led to the same conclusion of all of those threads. Early synthetic oils had significant problems with causing leaks because they had such high detergent properties, and they would cause problems with shrinking the seals, etc. Very quickly Most mainline synthetic oil producers change their formulation’s to prevent the seals from causing issues. Yes excess varnish will be washed away and if that’s what’s holding your motor together, it will start causing leaks. That said if varnish is keeping your engine from leaking it probably needs to be resealed anyway. Net result is I don’t think synthetic oils of today will cause any problems with our engines. Plus, I agree with Some above in that synthetic oils are far better at handling the high temperatures inside of our engines. That said I run VR one and flip between synthetic or dinosaur oil depending on what I find. No leak issues.
Chris - Insta @chrisjbolton 1975 911s Insta: @911ratrod steel wide body, 3.6 conversion 1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line) 2001 996 Turbo - ~54k miles |
I've used M1 15-50 for 50 years in all my air-cooled over the years with never a problem.
change it every 5k or 6 months, if you want to pay more its your choice.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
