Momo collector
Looking for a performance diagram of a 3 litre SC engine with Solex carbs
Does anyone have a performance diagram of a 3 liter SC engine with Solex 40 carburettors? It would be great if I could get it. Many thanks
Mads from https://www.patipatina.com
Old 08-15-2024, 12:34 AM
gearhead
What do you mean by performance diagram? No 3l engine was ever delivered with carbs. It’s a cis engine. Any factory diagrams, like vacuum lines, would be for cis. What information specifically do you require?
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 08-15-2024, 04:33 AM
Momo collector
Hey Matt,
thanks for your reply. I know, the SC engine came with CIS but I have rebuilt an engine block and installed Solex carbs for purity reasons.
Here's the thing: In order to get a registration in a weird European country, I need a performance chart aka dyno chart of a similar engine (3 litre SC engine) with Solex carbs. Thing is, there is no place even in a 100 mls radius that could do a dyno run and I am not allowed to drive the car until it gets a rego. The registration authority is fine with a similar dyno chart with a same (near) spec engine. Hope that makes sense!
Cheers, Mads
Old 08-15-2024, 04:44 AM
The 9 Store
Make one up on your computer.
I think I just said the quiet part out loud.
All used parts sold as is.
Old 08-15-2024, 05:43 AM
group911@aol.co's Avatar
Here is one for Webers. Change the name.
http://forums.pelicanparts.com/porsche-911-technical-forum/196186-weber-dyno-result.html
Thanks,
Bob
group911@aol.com
Old 08-15-2024, 11:47 AM
Banned
Are you still searching for this particular item?
The seller is ready to assist you at: kenneth.thurmond @ proton.me
Old 11-09-2024, 07:50 AM
Momo collector
Got what I needed - thanks guys for the help ✌️
Old 11-09-2024, 09:13 AM
PCA Member since 1988
It's a spam bot.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 11-09-2024, 04:29 PM
