Sudden No Start
My 1977 with a 3.2 swap was running perfectly, I had just taken it for a 20min drive and got everything up to temp, then stopped and shut off the car for a few minutes. Went back to start it again, there was a "click" then nothing. No fuel pump, no action at the gauges, no starter click or turnover. Thankfully this happened in my garage, I checked the fuses (none blown), wiggled the relays in the front fuse box, wiggled the connections to the ignition switch (as much as possible) -- still nothing. The light in the frunk still works.
I'm guessing the ignition switch went bad finally? How to tell if I need the full $900 assembly:
https://www.pelicanparts.com/More_Info/96434791701.htm?pn=964-347-917-01-M100&bc=c&SVSVSI=0563
Or just the switch?
https://www.pelicanparts.com/More_Info/96461301200.htm?pn=964-613-012-00-OEM&bc=c&SVSVSI=0563
Is there a relay or fuse hidden somewhere that could be causing this that I should check? I figure if it was the starter relay that the fuel pump would still turn on, but I am getting nothing when I turn the key.
Old 10-14-2024, 03:39 PM
You need to troubleshoot with a 12v test light or a voltmeter and see where voltage is present or not. If you’re willing to do that folks here can walk you through the steps.
If you just start throwing parts at it you will likely waste a lot of time and money
Old 10-14-2024, 04:17 PM
Check your battery and cables first.
Tony
Old 10-14-2024, 06:55 PM
If your 3.2 swap includes the original electronics the fuel pump only runs when the engine is cranking.
Old 10-15-2024, 02:38 AM
Check earth strap from engine to body too, bad connections here will cause all kinds of problems, I had a very similar issue years ago, car would start fine, take it for a run, then go to start it again, just a click, check all the simple stuff first.
Hope this helps.
Ant.
"But instinct is something which transcends Knowledge
We have undoubtedly certain finer fibres that enable us to perceive truths when logical deduction or any other wilful effort of the brain is futile"
Nikola Tesla
Old 10-15-2024, 02:54 AM
Schulisco's Avatar
Supposingly its the ignition switch.. But you have to rule out if its a mechanical or electrical problem:
https://forums.pelicanparts.com/porsche-911-technical-forum/348306-ignition-switch-inside-fix-start-lockout.html
Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL.
Old 10-15-2024, 03:34 AM
When my '85 would do that intermittently, it turned out to be the braided ground strap beneath the engine.
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 10-15-2024, 05:57 AM
Very similar to what happened to my '78. I was convinced it was the ignition switch. Several folks on the board suggested checking grounds. My negative battery terminal was a bit loose and the ground straps from the battery to the frame and from the engine/transmission to the frame were pretty corroded. I replaced and tightened the battery cable and replaced the engine ground strap and the issues were solved.
So you may well need a new ignition switch, but check the easy, cheap stuff first.
1978 911 SC Targa
2007 Boxster (sold)
Old 10-15-2024, 06:22 AM
Update on the situation. Went back to the car and it turned back on once, then died again. Checked battery voltage, OK at ~12v. Tried again and it started right up. Voltages at 14v when running. Been driving it all week and no issues. Will check and clean the battery terminals and ground strap to be safe. Thank you everyone for your input. Still a bit of a mystery but hopefully after cleaning everything there is no reoccurrence.
Old 11-11-2024, 09:55 AM
Kind of Blue
MrBonus's Avatar
I had a similar intermittent issue. It turned out to be an ancient starter.
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel)
2024 Ford Bronco Raptor
Old 11-11-2024, 10:35 AM
