EMT/TechRescue Instructor
LED’s in H4 housing
My Halogen bulbs are too dim. Has anyone had issues with LED bulbs in a H4 housing. I’m thinking that they may get too hot because the headlights are pretty much sealed off in the headlight bucket.
David 1986 Iris blue 911 Cabriolet 2017 Ram 1500 Night edition 2025 BMW X-5 |
I have Phillips LED bulbs in mine. No issues.
1978 911SC with Lobster Interior - Zoidberg http://forums.pelicanparts.com/porsche-911-technical-forum/1126971-zoidberg-my-1978-911sc.html |
there are a ton of threads on this topic -- here's a recent one (I searched forum for "h4 led") https://forums.pelicanparts.com/porsche-911-technical-forum/1109529-h4-led-upgrade.html I've been VERY happy with higher wattage halogen bulbs in my H4 housings -- specifically http://www.amazon.com/exec/obidos/redirect?link_code=ur2&camp=1789&tag=wwwpelicanpar-20&creative=9325&path=https://www.amazon.com/CEC-Industries-Halogen-Headlight-Bulb/dp/B002CYTQH0 When properly aimed (KEY with h4s), even the standard wattage bulbs should be a clear improvement over our 86' sealed beam headlights. If your bulbs are currently "dim," I'd start by confirming they're properly aimed and that the reflectors/insides of lenses are clean before dropping $ on new bulbs.
I worked with a supplier to develop a set of LED H4 bulbs with projector housings that are completely plug and play into the H4 housing.
Sharp cut-off line even with the fluted lens and significantly brighter than the 100/55W halogens and Rennline bi-LEDs I had before. Best part is the headlights look completely stock when not on. ![]()
Those look good. What is the source to purchase?
Sent from my iPad using Tapatalk |
Went with the original Porsche Classic H4 LED (i know there are cheaper options). Huge, huge upgrade…
http://www.carrera-32.com |
I have a pair of Auxito LED's in my Hella H4 housings. Love them.
1986 Porsche 911 Carrera 3.2 |
Had a few folks reach out regarding the LED H4 projector bulbs that I have. I didn't want regular LED bulbs as they have a lot of glare when used in halogen housings.
The projector portion comes apart for ease of installation as it allows you to secure the clip onto the projectors without having to maneuver around the cooling fins of the bulb itself. Then you can insert the LED in. For my housings there was a small metal cover 'bucket' designed for a halogen bulb that needed to be removed. ![]()
LED Projectors
I wish I had seen the small style of LED projector Skunkworks posted sooner.
I've been looking for an option to replace my H4 Boslla Tricolor LEDs with a projector style for a while. While they are much brighter than my original H4 bulbs, the problem is my original H4 reflector bowls have lost their luster, and one a lot more that that other. I guess I could have bought new reflector bowls, but that's too simple! I opted to go for Morimoto M Bi-LED projectors with DRLs and flasher switchbacks, and retrofit them into the the original H4 buckets. The projectors work great with the brightness I want and well controlled distribution and cut-off. I got a couple '66 VW style clear lenses to try out a new look, but I'm not so sure with the resulting looks. I may go back to the fluted H4 lenses but I'm not sure how much that would affect the controlled distribution of the projector. I'm leaning towards painting the chrome and metal parts matt black as a winter project, then reassess whether to put the fluted glass back on. Before ![]() ![]() ![]() After ![]()
'82 SC non-original...with '86 Carrera interior...aero mirrors...968 roof antenna...JWest shifter...CR eletrocooler, alternator and fuse panel...RHD/Xfaktory ITBs...Bosch cops...EMU Black ecu...Adapt Motorsports crank/cam sensor, crank pulley...M1 cams...Achtungkraft GTK exhaust https://www.instagram.com/mango_911sc/ |
SkunkWorks what is a pair goes for ? |
SkunkWorks can you show a few pics of them installed? Also, how much juice are they pulling?
Tom Hutchinson 80 Targa / 81 Coupe / 71 Targa (in Porsche heaven) My Garage Build: https://youtu.be/H0n_NwEQVbs "If one does not fail at times, then one has not challenged himself." Ferdinand Porsche |
Gross
Here is the best thing your money can buy Quote:
SWB 912 - G50 Carrera - 986 Boxster - 997.2 911 Turbo - 958.2 Cayenne - 9Y3 Cayenne GTS SOLD: 958 Cayenne Turbo S - 997 Carrera 4S - 957 Cayenne Turbo Workshop Coordinator at Ehrlich Motorwerks instagram.com/patrickossenkop ehrlichmotorwerks.com |
I purchased these on eBay UK a yr or two ago. Philips LED-HL H4 bulbs at 5800K cool white light. I love them in my H4 housings with fluted lenses. Looks like they are about $125 + shipping.
I just have a hard time with the modern interpretations that force you to stare into the headlights...! These plugged in quite easily and haven't had any issues with heat or cutting out.
912E-3.2ss |
Porsche is selling the Philips LEDs, which are legal in certain countries. They are legal because they meet minimum requirements, but not because they are better than a quality halogen.
Counterclockwise?
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
I have holly retrobright classic 3k installed and they have been a very nice alternative for the OEM seal beams.
worth considering.
1983 911SC - Helibronze Metallic L966 |
I'm too new to PM you but interested in those LEDs.
PM sent. I've more sets in hand now.
